Making a 48re into a manual shift.
Old Feb 22, 2009 | 12:02 AM
Alaska Sunrise's Avatar
Well, as some of you may know, I tried my luck at outfitting a manual transmission for my needs. Although we succeeded in our attempt, it has proven too costly and complex to outfit one as a legal vehicle.
So, here's my question, I have found a good used truck (5.9 with a 48re) but can I modify the auto so that I have complete control over shift points and T.C.lock-up? If so, can I make it so the T.C. can lock up in first gear also? I can only compare this truck's 48re to how my uncle's 2008 6-speed auto behaves. I don't like the "loose" feeling of the 48re, but everything else on the truck is really good.
Old Feb 22, 2009 | 01:08 AM
cbrahs's Avatar
contact a tranny builder of your choice and ask them about doing a manual valve body. the lock up would be as simple as adding a lock up switch.
Old Feb 22, 2009 | 02:49 AM
trksrfun's Avatar
^^^^^ what he said..
Old Feb 22, 2009 | 09:07 AM
gmctd's Avatar
An after-market low-stall torque convertor will really improve your relationship with any 47\48xxx series slush-box - the oem hi-stall unit is a real warranty-enhancing dog, feels like your Dodge is in quick-sand - add a TRANSGO shift kit and you'll need one of those mouthpieces boxers use to absorb impact-shock - add a TCC switch, learn when to use it, and yer good to go - works fine, lasts a long time.........
Dave7060
0
Feb 13, 2012 05:03 PM
Lost Lake
May 31, 2011 07:29 AM
#2 only
Sep 7, 2008 07:42 PM
Nuttymopar
Sep 7, 2005 10:18 PM
Roadking54
Sep 16, 2003 12:57 AM
