Lug thread?
Old 06-08-2010, 01:11 PM
Mexstan's Avatar
Lug thread?
Does anybody have any idea of what size and thread are on the wheel lugs? Is it metric or imperial?
I have tried a bunch of nuts on the lug but every one of them only go for half a turn and then stop.
I am guessing that it is 12 mm fine thread. Or maybe a fraction above 12 mm.
Old 06-08-2010, 03:01 PM
jlipskoc's Avatar
Rockauto.com might have what you need, i remember seeing they sell replacement ones a while back.
Old 06-08-2010, 03:02 PM
checkster's Avatar
Pretty sure they are 9/16"-18
Old 06-08-2010, 03:42 PM
Fordzilla's Avatar
A thread gauge is a handy thing to have in a toolbox......Ben
Old 06-08-2010, 04:08 PM
Mexstan's Avatar
Thanks, but I don't need the lugs or the nut, just used this as an example of the thread size for a nut I require.
Old 06-08-2010, 04:10 PM
Mexstan's Avatar
You are perfectly correct. Have considered buying one for years, but over the years have only had the need 2 or 3 times, so can't really justify it.
Old 06-08-2010, 08:04 PM
d zul's Avatar
Thats what they are. The nuts that hold every thing to the hub is also the same 9/16" x 18 also.
Old 06-08-2010, 08:14 PM
Mexstan's Avatar
Dang, I could have sworn that they were metric as so much of the rest of the truck is metric. Having had two of you tell me this, now I can go out to see if I can find one nut of this size.
Old 06-08-2010, 08:27 PM
bansh-eman's Avatar
Nope they are 9/16 x 18 I just put a set on my truck when I installed my new lift and tires last weekend.
Old 06-09-2010, 12:45 PM
Mexstan's Avatar
Problem solved. Tried many nuts and not one would screw on more than half a turn, so have to presume that every one of them were metric. Today I obtained a nut from work that screwed on perfectly. It is overkill for the job as it is an aircraft quality 12 point tension nut with a built in washer (large footprint) and an extremely good self locking device. (NAS spec) I can guarantee that this nut will not only never come loose, but will not fall off like the factory nut. Now I can drive with confidence again.
schoust
10-21-2009 10:09 AM
dieselJon
03-06-2008 04:58 PM
Trebor
09-14-2006 04:52 PM
gerryz
01-02-2003 11:32 PM
dart racer
11-10-2002 10:10 PM
Quick Reply: Lug thread?
