LP again!!!
Old Sep 9, 2005 | 12:54 PM
Mikedeere's Avatar
Angry LP again!!!
I have a weird problem, my lp pressure is 8lb. idle,7lb. crusing, at wot it jumps to 10 or 11 lb. is that the lp? I think maybe! The lp is about 4 months old. it started out at 16lb. at idle and sometimes it does that now?? Could it be electical ?? Help
Old Sep 9, 2005 | 12:59 PM
CTD NUT's Avatar
Erratic fuel pressures are a typical sign of a LP that is headed South.
Old Sep 9, 2005 | 01:04 PM
Mikedeere's Avatar
Thats what I was afraid of. Do you know how to install a Holley blue back near the tank?
Old Sep 9, 2005 | 02:24 PM
farmer dave's Avatar
I have heard some say that they have had problems with the holleys also. I would go and get something that will not give you any problems so I would never have to deal with it again.
Old Sep 9, 2005 | 03:02 PM
Buckshotmckee's Avatar
Agreed.
I put the FASS II on several months back, and I have never looked Back.
Old Sep 10, 2005 | 08:16 AM
Bob H's Avatar
My truck was doing the same thing. Was putting on another new lift pump and found out it was sucking air. Put hose clamps on the connection between the steel line from the tank and the rubber line to the lift pump and the problem was solved. DODGE SHOULD HAVE PUT A CLAMP THERE AT THE FACTORY. Just sticking a rubber hose over a steel line is bound to leak after a few years. I'll bet a lot of pumps were sold just for this reason. Ever notice all the aftermarket set up's are clamped?
Old Sep 10, 2005 | 08:23 AM
Geico266's Avatar
I agree. The "quick disconnects" are an air leak waiting to happen. I took my tank off working on the sending unit and cut those off years ago, and DOUBLE hosed clamped them all. Hose clamps are cheap, being stuck on the side of the road is not.
Old Sep 10, 2005 | 01:00 PM
Mikedeere's Avatar
I`ll check that (Now) Thanks I`ll let you know.
Old Sep 10, 2005 | 02:01 PM
Mikedeere's Avatar
Gieco 266 You just saved me 200.00 thanks. The connection at the lp from the tank was not seated real good. But I think I will put rubber hose on it from the hard line to the pump so I won`t have to worry about it. Thanks again
Old Oct 6, 2005 | 08:57 AM
windkid4's Avatar
This was an excellent post, I was seeing goofy pressure reading on my 24v. I was seeing 15+ at startup, then down to 3 – 4 PSI. I was going to swap the LP pump out this weekend, but I put a clamp on the supply line to the LP, PROBLEM SOLVED. It’s stays at 15PSI + if I get on it, it pulls down a few PSI.
Thanks People, you guys saved me $200.00 cash + 2 hours work. I’m hauling a tractor over to Denver next week so I will see for sure how it behaves.
Yep, I'll bet several LP were replaced due too this problem area.
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
chuck3
Feb 1, 2005 07:47 AM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
