LP Problems
Old Oct 3, 2005 | 01:35 PM
booker47885's Avatar
LP Problems
My FP with the stock LP was running about 10 psi at idle and dropping near 0 psi at WOT. So I bought the Vulcan Kit and installed a Holley Blue on the frame in front of the tank. Now my FP is 6 to 7 psi at idle and 0 psi at WOT. I thought maybe there was a restriction in the tank line so I blew back through the line with 90 psi to make sure it was clear but there was no change. The only solutions I can come up with are the pump is sucking air or the pump is bad. I only used the rubber hose from the Holley to the filter housing and I didn't install the regulator. Thanks for the help.
Old Oct 3, 2005 | 01:56 PM
crobtex's Avatar
Fuel filter......?
Collapsed line between tank and Holly.....?
Old Oct 3, 2005 | 03:00 PM
Gotlift01's Avatar
Sounds like a REALLY clogged filter or a pinch in the line somewhere not allowing it to flow right. With the Vulcan kit and the Holley blue you should be in the teens on fuel pressure!!
Old Oct 3, 2005 | 04:50 PM
CTD NUT's Avatar
Is the Blue pump used or new?
Old Oct 3, 2005 | 05:02 PM
LP Problem
I changed the filter but only saw about 1 psi gain. The pump is new. Thanks.
Old Oct 3, 2005 | 06:10 PM
I moved my FP guage to the incoming side of the fuel filter instead of the out going. With it there I see 11psi at idle and 8psi at WOT. I think I've got a problem with the Prime-Loc. I've been thinking about getting rid of it since I got the truck maybe it's time.Thanks.
Old Oct 3, 2005 | 08:11 PM
Huff nPuff's Avatar
The Fuel Module in the tank is very restrictive and can leak air
Do your self a favour,install mopars updated lift pump module assy.If you are over 400hp you may need an additional lift pump installed in the stock location.The P/N is 05175538AA its one of the options available to open up the fuel module.
Old Oct 6, 2005 | 09:12 AM
Thanks for the help guys. Anybody know were I can find a used Fuel Filter Cannister for a 99' reasonably priced?
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
