low pressure fuel pump
Old Mar 13, 2004 | 04:27 PM
truknut's Avatar
can anyone tell me if they have ever observed the workings of the low pressure fuel pump? here is my situation... I can't get fuel up to the filter. After much trial and error I removed the pump and looked inside the housing at the lever. The rod does not move at all. The hand prime is not moving anything that I can see. Is it possible the diaphram or shaft is stuck?
Old Mar 13, 2004 | 04:50 PM
country's Avatar
honestly if you already have it off don't worry with the old one just go to napa or your local parts store and get a new and slap on it for about 50 bucks
Old Mar 13, 2004 | 07:15 PM
truknut's Avatar
Thanks for the reply. Already in the process, unfortunately it won't be in 'til Mon. so I figured I'd ask just to satisfy my feelings. Thanks again
Old Mar 14, 2004 | 08:29 AM
Here's a tip that might make your life simpler if you pulled the pump from the top. I found out from this site that it's easier to R&R the pump by pulling the LF tire and working through the fenderwell. Im so dumb I did it twice from the top and never thought of pulling the tire off.
Old Mar 14, 2004 | 08:54 AM
jleonard's Avatar
I recently replaced mine...from the top. I used one of those tire steps . I don't know why you'd want to do it thru the fender...changing the pump is maybe a 10 minute job...it would take a lot longer than that just to jack the vehicle and remove the tire.
That's my opinion anyway. Whatever works.
Jay
Old Mar 14, 2004 | 05:02 PM
truknut's Avatar
It came out real easy. I also used a small stepladder. I could imagine a 4x4 being a little tough from the top. I was surprised that it just quit without any warning.
Thanks,
Rick
derceg
Dec 23, 2009 07:24 PM
jwb600
Jan 28, 2008 03:26 AM
bc3
Dec 1, 2007 10:19 PM
mudwisr2
Sep 25, 2007 07:04 PM
Spooler
Feb 12, 2006 11:43 AM
