Looking for Gauges
Old 03-09-2010, 06:51 PM
ddszero's Avatar
Question Looking for Gauges
OK I'm looking for a gauge set for my truck. All the ones I find have a Trans temp gauge in them and I have the 6sp do I really need the Trans temp gauge ? I am looking at a 1600 pryo and a 45lb boost gauge maybe from Auto Meter. What other gauges would be helpful? I am planning to use a dash pod mount instead of a pillar mount.
I am also planning to install a Quadzilla Rail Pressure Gauge for my fuel system.
Would it be better to invest in the Edge Attitude with out the Edge Juice installed? The Edge Insight is only for the 2006 and up. Is it even possible to use the Edge Attitude like the Insight? Or will the mechanical gauges be the best bet?
Any and all ideas and comments are welcome.
Thanks.
__________________________________________________ _____________________
2005 2500 Crew Cab short bed 4x4 with a NV5600 3.73 With Limited Slip
111,000 Miles, K&N Drop in filter
12K Mile Marker Front Mounted winch
BFG KO AT 285/70 R15
LEER Camper Shell (my puppies BIG Kennel)
Old 03-09-2010, 07:06 PM
1985cucv's Avatar
60 psi boost gauge there is a bunch with fuel pressure boost and egt you just have to look around i think diesel manor sells them the dtr store might even sell them
Old 03-09-2010, 07:42 PM
Soot For Brains!
got_soot's Avatar
60psi boost guage and go with a mechanical guage like a autometer setup or isspro.. also use the the fuel pressure inplace of the tranny temp.
Old 03-09-2010, 10:34 PM
ddszero's Avatar
What would be a better for a pryo 1600 or 2000?
Old 03-10-2010, 12:17 AM
WhiteMule's Avatar
I would go with a 1600*. You need to be shutting it down before you reach that temp anyway.
Old 03-10-2010, 12:23 AM
Soot For Brains!
got_soot's Avatar
I 100% agree with that
Old 03-12-2010, 01:18 PM
ddszero's Avatar
Another level of questions
I am looking around to buy my gauges and I am finding a Pre and Post turbo for the Pryo gauges. Which one should I be using?
Will using a Boost Gauge Fitting "Boost Bolt" give me the correct boost reading?
Thanks.
__________________________________________________ ___________________________
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
Duckman1993
09-12-2006 07:50 PM
estesbubba
07-18-2006 04:35 PM
AggiePhil
01-30-2005 01:15 PM
Quick Reply: Looking for Gauges
