Looking for Gauges
OK I'm looking for a gauge set for my truck. All the ones I find have a Trans temp gauge in them and I have the 6sp do I really need the Trans temp gauge
? I am looking at a 1600 pryo and a 45lb boost gauge maybe from Auto Meter. What other gauges would be helpful? I am planning to use a dash pod mount instead of a pillar mount.
I am also planning to install a Quadzilla Rail Pressure Gauge for my fuel system.
Would it be better to invest in the Edge Attitude with out the Edge Juice installed? The Edge Insight is only for the 2006 and up. Is it even possible to use the Edge Attitude like the Insight? Or will the mechanical gauges be the best bet?
Any and all ideas and comments are welcome.
Thanks.
__________________________________________________ _____________________
2005 2500 Crew Cab short bed 4x4 with a NV5600 3.73 With Limited Slip
111,000 Miles, K&N Drop in filter
12K Mile Marker Front Mounted winch
BFG KO AT 285/70 R15
LEER Camper Shell (my puppies BIG Kennel)
? I am looking at a 1600 pryo and a 45lb boost gauge maybe from Auto Meter. What other gauges would be helpful? I am planning to use a dash pod mount instead of a pillar mount.I am also planning to install a Quadzilla Rail Pressure Gauge for my fuel system.
Thanks.
Another level of questions
I am looking around to buy my gauges and I am finding a Pre and Post turbo for the Pryo gauges. Which one should I be using?
Will using a Boost Gauge Fitting "Boost Bolt" give me the correct boost reading?
Thanks.
__________________________________________________ ___________________________
Thanks.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
