Longer the tip better the sound???
Old 04-08-2007, 06:18 AM
LilBigd02's Avatar
I just wanted to know what will sound better?? 4x6x18 or 4x6x24 both of them rolled tips. Hoping to make it maybe a little louder and more deeper sounding which one will do the job. Thanks
Old 04-08-2007, 06:21 AM
megafast's Avatar
I personally can tell very little difference from a tip alone. You plan on sliding it over the stock exhaust the same amount anyways, so length shouldn't matter? Correct me if I'm wrong, please!
Old 04-08-2007, 06:24 AM
LilBigd02's Avatar
I thought maybe longer the tip the more echo you would get out of it I could be wrong though.
Old 04-08-2007, 08:36 AM
Luvnacumns's Avatar
Exactly.... The tip acts like a megaphone.. THe longer the more it echo's in there..
Shane
Old 04-08-2007, 08:44 AM
LilBigd02's Avatar
That's what i would have guess. I think i might try the 4x6x24 just because it would look better on my truck anyways.
Old 04-08-2007, 08:52 AM
t-boe's Avatar
I get comments on mine all the time. Although some say "Why do you need such a big exhaust?" my answer "Because I do."
Old 04-08-2007, 08:56 AM
LilBigd02's Avatar
where is the best place to buy that size tip from??
Old 04-08-2007, 09:04 AM
t-boe's Avatar
I got mine from ebay.
Old 04-08-2007, 09:13 AM
mikmaze's Avatar
just a heads up, if you push that tip to the outside edge of your rear tire, it will help with keeping the droan from inside your cab, gets the sound out from under your truck, and keeps it from gettin in so bad.I ran a string line from front tire to rear tire, across the sidewalls and pulled the tip to eve with this line, marked the location, and cut the xtra off of the magnaflow , then slid the tip back on and tightened the retaining bolt. Silverline tip, ebay as well. pics in gallery
Old 04-08-2007, 10:10 AM
rjm022's Avatar
http://cgi.ebay.com/ebaymotors/6-X-2...spagenameZWDVW
Old 04-08-2007, 10:12 AM
MAN
MAN's Avatar
I got a slightly used MBRP 304ss 4"x6"x36" angle cut exhaust stack off Ebay. I will get it put on this week and get some pic's up. It should come out right at the corner of my rear bumper.
Old 04-08-2007, 11:31 AM
duddin10's Avatar
Diesel's are different than gasoline engines. While on a gasoline, putting exhaust with echo tips does affect the sound , it is not the same on diesels. I asked that exact question when I bought my muffler and tip. On diesel's the tip does not affect the sound at all. The tip is just for looks.
Old 04-08-2007, 11:38 AM
kelley15's Avatar
Duddin10, I have to disagree with you. As was stated above,with a larger tip you are adding a "megaphone" and it most definitely changes the sound. Just like putting a cone or megaphone to the mouth.
krazydher
25
04-15-2010 12:37 PM
Txwelder
02-22-2008 04:55 PM
Shanevrr
38
06-29-2006 10:27 PM
Graphite600
13
01-28-2005 10:08 AM
DanTana
09-13-2004 09:27 PM
Quick Reply: Longer the tip better the sound???
