Lift pump vs Piston pump ?'s
Old Aug 24, 2011 | 02:41 PM
GIT-R-DONE's Avatar
What is the reason you guys are switching from the lift pump (stocker) to the piston pump?
What are the differences between them ...pressure...longevity....
How does a piston pump operate...the same as the stocker run off the cam....
Is there a certain piston pump you buy for it (and from who)?
Is there a pressure difference between them?
I am looking in to this and just have alot of questions about it as for the reasons and how ths piston pump works. TIA
Old Aug 24, 2011 | 07:08 PM
BILTIT's Avatar
More pressure/volume. Yup off the cam but uses a piston VS diaphram on the stocker.
From ''the stickies''
https://www.dieseltruckresource.com/...ad.php?t=93722
You can but the whole upgrade kit here:
http://www.dieselautopower.com/produ...ton%20pump.htm
Old Aug 24, 2011 | 07:13 PM
BearKiller's Avatar
Many reasons to upgrade, the most important being that a diaphragm-pump (the original issue) can rupture and pump fuel into the crank-case, whereas a piston-pump cannot.
The piston-pump holds a steady 15-ish PSI, as to the diaphragm's 3- to 7-PSI.
The primer-pump on a diaphragm-pump is somewhat particular as to where the cam-lobe must be oriented before it will work and then it takes a lot of pumping to move much fuel.
The primer on a piston-pump seems to care not what the orientation of the cam-lobe is and will pump quickly and strongly.
Etc. Etc.
Old Aug 24, 2011 | 07:22 PM
speed75's Avatar
Why do you need the spacer between engine and pump on the piston pump
Old Aug 24, 2011 | 10:27 PM
BearKiller's Avatar
Because the piston-pump is designed to work on several different makes of engines, not just Cummins.
The spacer is required to place the operating-rod at the correct position in relation to the cam-shaft.
Some applications use no spacer; the 6BT requires a 3/16" thick spacer; some require more; some less.
The bolt-pattern and overall flange shape of lift-pumps is pretty much standard on nearly all smaller engines, be they gas-burners or diesels.
PapeCAT
Dec 9, 2017 03:23 PM
BurrisWill
May 29, 2009 12:58 AM
Underpsi
Dec 5, 2005 08:20 PM
vinny
Nov 20, 2005 06:58 PM
CTD99
13
Aug 23, 2005 10:55 PM
