just another lp or gauge problem
Old Apr 6, 2006 | 03:31 PM
tempoffroad's Avatar
here is the deal i just put the vulcan relocator and big line kit on and it awsome have 14 at idle and no less than 12 with the edge comp on at wot but 2 times now when i crank the truck pressure is good then falls to about 4-6 and stays. I can cut it off and back on and run no problem. Its like its sucking air or something. Any ideas. only happend 2 in 2 weeks.
Old Apr 7, 2006 | 09:52 AM
Timmay2's Avatar
Pressure drops as resistance drops. Seems to be normal with the big flow kit to have pretty low psi *at times* for awhile.
Id say keep driving and just make a note of when it does it.. Eventually goes away from what ive read. I dont have the kit myself tho. Looked into getting it and decided to leave er stock.
Im assuming you went through the whole bleeding of fuel system etc etc??
Ls1z28fbody
Nov 27, 2006 08:03 PM
snowrodeo
Oct 9, 2006 09:11 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
callum
Nov 21, 2004 07:04 PM
