2001 HO Confusion
Old Apr 6, 2006 | 02:28 PM
willd's Avatar
2001 HO Confusion
Hey guys, I've found a 2001 Cab and Chassis with a goosneck bed already on it, the seller is about 250 miles away but it's at a fair enough price to drive that far away if it's as good of a truck as he claims. Now the problem is he claims it's a High Output with the 6 spd but I checked the vin number and according to it, it is just the reg 24 valve. Does anyone know if maybe these vin decoders may be wrong or is he bluffing. And also can ya'll think of anything specific I need to get him to take a picture of or describe before I make the 250 mile drive to test drive/purchase this truck? Thanks Guys!
Old Apr 6, 2006 | 04:15 PM
Patrick Campbell's Avatar
To my knowledge, if it has a 6spd it is a HO unless it was swapped or upgraded to a 6spd.
Old Apr 6, 2006 | 04:46 PM
Andy505's Avatar
That is correct. For 2001 and 2002 trucks all 6-speeds from the factory also came with the HO motor. Unless the 6-speed was swapped in aftermarket, then the truck is a HO.
Old Apr 6, 2006 | 05:20 PM
RAM2940's Avatar
You can check the engine data plate on the left side on timing cover this also has engine serial number on it.. If a H.O. should have 245hp and 505 torque(i think) unless that was swapped also.
Old Apr 6, 2006 | 05:25 PM
Andy505's Avatar
another fact....actually mine just says 245 horsepower...there may be a torque rating on the data plate but I havent seen it.
Old Apr 6, 2006 | 05:32 PM
RAM2940's Avatar
Does the VIN have a 6 or a 7 in the 8th digit, I know the 7 is for H.O. and 6 is for S.O.
Old Apr 6, 2006 | 05:38 PM
Andy505's Avatar
I believe that is for only the 2001 model year...which does apply to willd's question.
My truck is an '02 and the 8th digit is a C which is the HO and 6 is the SO.
They must have changed the 7 to a C when the '02's came around.
Old Apr 6, 2006 | 08:28 PM
willd's Avatar
That's the problem, it has a 6... The 6 spd was only availible in the HO right?
Old Apr 6, 2006 | 08:37 PM
willd's Avatar
I ran the free carfax and for engine type it says: (5.9L L6 HPDI TURBO DSL)....this may be a stupid question but what does the "HPDI" stand for? Thanks guys
Old Apr 6, 2006 | 08:49 PM
Floorman's Avatar
high output turbo diesel HPTD 10 hp aint going to make that big a diff anyway just bomb it
Old Apr 6, 2006 | 09:33 PM
graphitecumnz's Avatar
just add a TST box and forget about whether it's a H.O. or S.O.
Old Apr 6, 2006 | 10:36 PM
possum67's Avatar
well the 6 spd is a heaver trans than the 5 spd if by chance it was a 5sd so truck it has been upgraded not a bad thing 2 from my expernce the so's seem to have gotten better fuel milage i had a 01 western hualer ho6sp it would get 17 mpg on its best days my 01 sport 5 spd gets 20+ as long as i keep my foot out of it i wouldnt be scared just cause it might be a so truck there both great enigines
Old Apr 6, 2006 | 11:52 PM
Ph4tty's Avatar
6 speed on a 01-02 is a HO, but if you're looking at trucks buy the one with the setup you want- transmission, capacity, condition,.. more than the 10 hp in the HO vs SO. The six speed has shorter lower gears than the 5 speeds which makes it ideal for towers but makes for busy shifting in daily driving.
Ask about the lift pump and the injector pump and if they're OE or what warrenty work has been done. Turn the key 3 times then leave in the on position w/o starting in order for codes to display on the odometer. If possible check fuel pressure- or have him check it before you go.
I bought a truck and had to turn around and buy an injector pump and lift pump 6 months later =\
Old Apr 6, 2006 | 11:58 PM
willd's Avatar
Thanks Phatboy, are there any certain codes to look for? Thanks
Old Apr 7, 2006 | 04:27 AM
Ph4tty's Avatar
p0216 is a bad one. Click tech facts on the top of the page for more.
