interior plastic trim paint
Old 12-21-2008, 08:17 PM
pigeonman's Avatar
Question interior plastic trim paint
I've noticed the plastic on the door panels and around the windshield trim is starting to fade from dark red to a pink and in some parts white on my '94 since I moved over here . Welcome to Arizona and its incredable heat and UV !
Years ago you could buy a spray bomb that was specifically for plastic interior trim , it worked super and really bit deep into the plastic and wouldnt peal off . Now I hear they have reformulated it ( to protect us from ourselves ) and it doesnt stick worth a darn . I've actually seen it where you could get a loose end and peel it like an onion . Not good !
Any suggestions as to a brand name or place I could buy the good quality stuff ? I wonder would the guys who go around to the dealerships to spruce up their used cars have the good stuff anymore ?
Thanks mucho ,
Pigeonman Bob
Old 12-21-2008, 08:30 PM
Old Hat's Avatar
I have used them, not cheep but real good results
http://www.worlduph.com/
Old 12-21-2008, 09:46 PM
Silver R/T's Avatar
this paint worked pretty well on restoring black on my plastic parts in my Charger
http://shop.oreillyauto.com/productd...artNumber=TP70
Im not sure if they have every color.
Old 12-22-2008, 04:49 PM
atc250r's Avatar
Dodge sells the interior paint to match our trucks (at least they did 5 years ago). I painted my pillar pod to match the stock interior and it was a perfect match.
John
Old 12-22-2008, 07:24 PM
J Lent's Avatar
Any paint supply store can mix you a pint of your interior color.
Old 12-23-2008, 08:13 PM
pull-do's Avatar
I called a guy that installed the gauge pods on the side, he told me to buy some "Bulldog Adhesion Promotor" in the spray can and then I got the paint code from my Dodge Manual, for the trim, took that info to O'Reilleys and they mix it and put it in a spray can for you.
Also bought the Bulldog there, that crap works, the paint job is tough as nails.
Old 12-23-2008, 11:54 PM
Silver R/T's Avatar
they should be able to put it in a spray can for you.
Old 12-24-2008, 06:07 AM
J Lent's Avatar
I don't want to use aerosol paint. Aerosol paints dry, spray gun paints cure. They last longer. I add a little reducer to my paint & it burns into the plastic. You can scratch aerosol paint off with your finger nail, because it isn't cured or burnt in.
95ram
08-13-2009 10:59 PM
STATELINE
03-07-2009 06:08 PM
kreynolds
07-17-2007 06:32 AM
fishin fever
04-12-2006 12:03 AM
Alec
09-08-2004 07:59 PM
Quick Reply: interior plastic trim paint
