inside the pump
Old Aug 16, 2005 | 07:34 PM
ihpower's Avatar
inside the pump
i am getting very broke and i still want to do more to my truck. i am getting ready to get a htt stage 3 turbo. my question is it really worth tearing into the top of the fuel pump to grind the afc lever and what ever else i can do in side there. i am just nervous about getting in there and screwing it up, i seem to be good at that. and i am not sure about adding the 3200 spring b/c of the stock auto transmission. i just know the spring and afc lever would be cheap but i dont want to screw it up and have to spend a lot of money
Old Aug 16, 2005 | 07:46 PM
fearthedeere's Avatar
man tell ya the truth, if your not gonna add the spring i wouldnt worry bout it. i would grind your fuel pin tho. and if your pump is turn up half as much as mine, youll be pushin enough fuel for the trubo. Im wishing now id got the stage 4
Old Aug 16, 2005 | 07:56 PM
G1625S's Avatar
It is definitely worth the effort to do the internal pump mods that are regularly discussed here. The question is, do you feel comfortable performing them? Nobody here can answer that question for you--that answer comes from the inside As for the spring, it'll be a breath of fresh air for your torque converter since the engine will now make power where the T/C begins to hold a bit, at least that's what the slushbox guys say More fuel mods like afc grinding and fuel pin grinding are what you need to worry about as far as tranny life. RPM's can't hurt the tranny....fuel can. And a turbo big enough to burn the fuel can speed the process along as well Go for the stage IV and the spring. Once you've been into the pump once, it's no big deal to tear it down again if you really need to fog out 4 lane highways later on You have gauges, right?
g
Old Aug 16, 2005 | 08:46 PM
ihpower's Avatar
i have got guages. what is involved in grinding the fuel pin and how hard is it.
Old Aug 16, 2005 | 09:12 PM
apwatson50's Avatar
theres grinding the AFC lever which is underneath the pump top which some people do while installing the gov. spring.
Then theres grinding the fuel pin, this is the pin in the top of the pump that travels up and down while referencing boost, this raises fueling levels as boost increases. I haven't done this but it can't be too dificult. I hear it is easiest with a dremel type tool.
Old Aug 16, 2005 | 10:36 PM
hainesly's Avatar
http://dens-site.net/Dodge_CTD/Governor_Spring/
I read through this once quickly and got coRnfused I'll read through it a few more times and then decide if I want to attack this by myself, but someday it will be done At one point he has a caption under a pic that says this is the foot everybody is talking about grinding off and I still wasn't sure what I was looking at. Looked to me like there were two different levers with "feet". Who knows which one he's talking about????
Old Aug 17, 2005 | 06:50 AM
G1625S's Avatar
Thanks Wannadiesel
Old Aug 17, 2005 | 05:52 PM
hainesly's Avatar
Yeah....I went back and looked at that pic and it seemed obvious the second time Thanks for the conformation!!
Bryan
Old Aug 17, 2005 | 06:36 PM
Man, with POD's you are pushing your luck on the stock automatic to grind the AFC lever. If it's not a tow rig I think you'll get away with it for a while though.
Definitely do the 3200 RPM spring, it keeps the truck fueling hard all the way to the shift points. Much quicker and it feels a lot stronger.
If you decide to grind the fuel pin after you've already ground the AFC lever, you don't want to copy the PDR pattern or try to make it look like an Old Smoky pin. Only make the deep part deeper, leave the big end alone. The ground lever gives plenty of fuel at low boost, you want to try to delay adding more fuel until you have the air to burn it.
Old Aug 17, 2005 | 08:09 PM
ihpower's Avatar
i think i will hold off on grinding the AFC lever for now. bc this fall i will pulling waggons full of corn up hill and stuff. i will pull across the scale around 20,000 pounds when its full. i am still wondering about the fuel pin would it be alright to do that . if anyone would have a pic of there fuel pin groundit would be vey helpful
ELI
4969joes
Mar 28, 2010 05:26 PM
ADMOPARMAN
Mar 9, 2007 06:43 PM
LITTLE B
Feb 21, 2007 06:55 AM
blueberry
Nov 4, 2006 08:32 AM
serious
Aug 16, 2006 10:58 PM
