Input shaft Installation NV4500
Old 12-28-2007, 10:31 AM
riddle789's Avatar
hey, i have an 1 3/8 input shaft for my nv4500, anything special i need to know about installing it, looks like you just take the four bolts loose on the retainer plate and swap it out. just dont want to screw anything up. any help or tips would be appreciated.
thanks
Old 12-28-2007, 11:21 AM
97' CTD's Avatar
Straight forward process .
Brandon
Old 01-08-2008, 08:01 PM
ILLINOISRAM's Avatar
Hey, This Is Just What I Know But Haisley Says All You Have To Do Is Unbolt And Replace, But My Tranny Shop Put It To Me This Way, You Wouldnt Put Your Motor Back Togehter With The Wrong Preload, So Why Would You Dot That To Your Tranny, Especially Behind A Cummins. Just My Two Cents. Tim
Old 01-08-2008, 09:52 PM
Tate's Avatar
How did your tranny shop adjust the preload on the bearings? Both of the trannies I've changed the input shaft on have had zero shims between the casing and the input shaft carrier.
Old 01-08-2008, 10:45 PM
Tate, That Is The Problem. The Shims Are On The Back Of The Tranny Under The Nut. To Much Preload And Lots Of Torque Will Crush The Berrings And Or Build Alot More Heat. Not Enough Preload (basically Slop Or Play) And You Could Blow The End Out Of The Box. Both Ways Are Costly To Fix. I Also Did My First One The Easy Way, Input Shaft Bearing Shot Craps And Ruined The Input Shaft. $1350 For The Tranny And Another $750 For A Second Input Shaft Changed My Mind. The Next One I Did, I Swapped Myself Also, THEN Had The Shop Pull The Back Off And Shim For 200 Dollars And A Piece Of Mind.
riddle789
12-29-2007 06:39 PM
Muddin_dude06
05-02-2007 06:50 AM
J Lent
Competition / Pulls / OffRoad
13
04-16-2007 11:33 PM
nates90
11-15-2006 11:13 AM
Captain
11-12-2006 07:18 AM
Quick Reply: Input shaft Installation NV4500
