injectors, sugestions
Old Jan 26, 2007 | 06:02 PM
olddodgetruck's Avatar
i need a set of injectors. im thinking about 150 hp but wouldent mind going bigger. but worried about egts. those of you with a 14cm turbo i was wondering what you are running for injectors and egts
Old Jan 26, 2007 | 06:06 PM
dieselfan's Avatar
what do you have, SPS 62/14? do you tow?
Old Jan 26, 2007 | 06:11 PM
62/14 with an edge comp i tow on occasian, only my offroad truck about 7000lbs max
Old Jan 26, 2007 | 06:14 PM
Jetpilot's Avatar
I run that exact setup and use F1 Mach 4 injectors (150 HP). This combo yelids 500-525 RWHP. Going larger with your turbo will pretty much only increase egt's not HP.
Doug
Old Jan 26, 2007 | 06:15 PM
dieselfan's Avatar
i think you wold be fine with 150's, maybe a little bigger. you just wont be able to use the comp on that high of a setting for long, but thats with any sticks you choose+ fueling box= heat. i would go with at least 150hp.
any plans for twins later on?
Old Jan 26, 2007 | 06:23 PM
how would mysuper fat shaft work with 200hp sticks and water/meth
Old Jan 26, 2007 | 07:02 PM
Jetpilot's Avatar
Its not a matter of heat.... Its a matter of oxygen density to allow for an efficient burn. You could run 220 HP sticks but the HP increase running a 62 turbo over the 150 sticks wouldn't be much. Yet the heat would be outta sight.
Old Jan 26, 2007 | 07:20 PM
BigBlue's Avatar
With 155hp injectors and a smarty and a 62/12 I can hit 1100* WOT. With the TST on 2 I can hit 1250*. With the TST COMP on 2, smarty, 155hp injectors, and turbo I'm blowing almost everyone off the road. If you need anymore than that your nuts. Boy I can't wait for mach 8's and twins.
Old Jan 26, 2007 | 09:15 PM
blackdiesel's Avatar
Registered
i think i would do the 4's.
im running a sps 62/14 and with my m6's she gets real toasty when under a load
Old Jan 27, 2007 | 05:42 AM
now my next question is will a smarty/edge comp stack be better than just an edge drag comp with 150 hp sticks
Old Jan 27, 2007 | 11:22 AM
MSquare's Avatar
Most folks say the Smarty (timing) and TST (no timing) is the ultimate combo if you are going to stack.
I have heard lots are happy with the Smarty (no timing program) and the Comp (timing). I drove my truck with that combo and it was impressive!
Note, my first sentence said ultimate. I'm waiting for a TST in the mail so I'll know soon.
I know there are alot of guys posting very impressive dyno runs with the Drag, 150 injectors and an SO pump.
I am really happy with the way my truck runs with the Smarty and big injectors for daily driving. The TST should be fun.
Good luck.
Vintage Empire
Jan 30, 2007 08:36 AM
taken5875
Jun 8, 2006 10:35 AM
duallydave
Sep 17, 2005 11:43 PM
dodgeman01
Nov 29, 2004 09:05 AM
