injector pump removal
Old Dec 6, 2005 | 04:48 PM
norberg's Avatar
my injector pump is almost out.
I have all the lines and bolts out, but it is hanging up on the gear inside the gear housing.
I did remove the bolt from the from of the housing.
Is there anything else that holds the shaft in, or do i need to apply more force?
Old Dec 6, 2005 | 04:59 PM
You need to use a gear puller to pop the gear off the shaft. Make sure you don't drop the key.
Old Dec 7, 2005 | 01:28 AM
bgilbert's Avatar
I'd be careful using the term ' pop '. You don't want to pop it, you want to pull it . Someone might try popping it with a hammer LOL, not good .
Old Dec 7, 2005 | 04:18 PM
Well, then we could hand them their "Stupid" sign.
HUNTINNUT
Jul 27, 2013 11:40 AM
Jschlachta
May 26, 2009 06:42 PM
trik396
Jun 1, 2008 07:04 PM
kawi600
Jan 26, 2006 10:19 AM
