injector lines
Old 06-05-2009, 09:30 AM
mrploww's Avatar
injector lines
I am ordering up new injector lines because I have broken 2 of my stock lines due to previous owner removing the clamps. I contacted Scheid Diesel and they have 3 different size lines. I talked to someone there and he said there would be no problem going with a .093 line. I have a Hot Rod VP44, head work, FASS fuel system, I believe it has larger injectors, and is a 6 speed. He said the larger line causes some problems on an auto, but not on a manual. Will there be any reliability or drive ability problems with going to this larger line? I want to make sure I am not going to hurt performance by going to this or cause problems with towing.
Thanks for the help!!
Old 06-05-2009, 10:17 AM
dieselrob's Avatar
I would just buy the 2 new stock ones you need and save some money. You dodnt need them unless your running huge injectors and power.
4doogie
03-10-2006 01:46 PM
Gene007
02-27-2006 09:34 PM
rockjeep73
02-01-2006 10:34 AM
MrKen
02-25-2005 04:22 AM
hellotbone
09-01-2003 08:46 PM
Quick Reply: injector lines
