Will hooks in ceiling hold bed?
Old 12-15-2008, 02:55 PM
rock crawler's Avatar
I am about to lift my bed off to do the AD150 install. Do you think that large hooks screwed into the studs in the ceiling of my garage will hold that kind of weight?
Old 12-15-2008, 02:57 PM
mulisha's Avatar
that will work for sure, just make sure you anchor into your ceiling rafter's/studs.
Old 12-15-2008, 03:03 PM
Just a plain ole guy
1-2-3's Avatar
Two people should be able to lift the entire bed so it would be the same as two people walking in the attic at once. Just make sure the hooks catch some good wood.
Old 12-15-2008, 03:50 PM
rip 112's Avatar
It'll work. You'll be surprised how light that bed is.
Old 12-15-2008, 04:09 PM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
post pictures when youre done! even if it works! LoL
Old 12-15-2008, 04:39 PM
Administrator/Jarhead
madhat's Avatar
Well, first let's talk about what you have in the bed. If you have a spray in liner or tool boxes, I would not. To be safe, I'd put a 2X6 or 4X4 on top of the rafters, and run the hooks into that, so that the weight is more even.
Be careful. I would not work under it while it. Back the truck out or something.
Old 12-15-2008, 05:56 PM
homewrecker's Avatar
Why does everyone want to take the bed off for the install?Sure seems alot easier to drop the tank.
Old 12-15-2008, 06:07 PM
madhat's Avatar
I have done both, and I personally feel the bed removal is better/easier. You get the draw straw in where it sits with the tank in the truck.
I have done both, and that's just my personal feelings on the 'easier' part, but I have no 1/4 tank issues from the bed lift install vs. the tank drop.
Old 12-15-2008, 06:36 PM
ratsun's Avatar
X 2
I find lifting the bed easier also (only lift it 18-20"), but I have a hoist in the shop to lift it with. Plus it makes mounting the pump and everything easier
Old 12-15-2008, 08:46 PM
C Schomer's Avatar
The bottom of the rafters aren't meant to carry weight but will probably work - just look at the nail plates at the joints. If you want to make sure... tie in to the top board which is meant to take the rated load of the roof. Craig
Old 12-15-2008, 09:10 PM
Checkmate's Avatar
My advice also.
Old 12-16-2008, 09:47 AM
blownsmoke2's Avatar
We've done three FASS system installs. It is pretty easy to remove the bed. What we seem to have done that works the best was take some straps off of the bed tie downs and hook them to my backhoe bucket and lift it off. Oh ya not everybody has those laying around. No a couple of guys lifted the bed off the first one we did.(8ft long box)
AggieJustin
09-16-2011 10:43 PM
Garrett5462
11-08-2007 05:34 PM
Mark Thomas
07-02-2004 08:31 AM
Quick Reply: Will hooks in ceiling hold bed?
