High Idle (Again, Maybe different)
Old Feb 16, 2006 | 11:02 AM
Duallydog's Avatar
This has many threads about the high idle, but I thought I would skip abunch of reading and probably no one has asked this about it. Can the high idle be turned up for regular driving. With a load turn it up, and maybe turn it down for longer idling.
Old Feb 16, 2006 | 02:24 PM
Hounddog's Avatar
You mean like idled up and drive??? If thast the question is not with the stock setup.Sounds dangerous.
Old Feb 16, 2006 | 02:26 PM
CenTexDodger's Avatar
It only works for idling the truck in Park. Once you put your foot on the brake to shift, it idles bick down to normal~750 rpm or so. You can idle it up from 1000 to 1400 or so, but only in park
Old Feb 17, 2006 | 12:13 AM
ASHNBAK's Avatar
Neutral works too. Don't even need to set the brake.
Old Feb 17, 2006 | 05:23 AM
rammtuff's Avatar
Yes it is called cruise control.
Old Feb 21, 2006 | 02:51 PM
Duallydog's Avatar
I mean like the older trucks you could turn the idle up and down for driving. My dads 2000 runs at around 850rpm. Put less strain on the engine with a load.
Old Feb 21, 2006 | 05:54 PM
Hounddog's Avatar
A 2000 24 valve had adjustable idle? Thought that was only 12 valver's?
Old Feb 22, 2006 | 09:52 PM
Duallydog's Avatar
Apparently it has been adjusted on. It idles at higher rpms than mine and the 97 we had. It looks like it was used as a hot shot truck (I wouldn't have since it has 3.55 rear end), they might have turned the idle up to handle heavier loads without touching the throttle.
kicker210
Dec 2, 2009 08:23 AM
dodgethis91cmns
Jun 11, 2008 04:40 PM
jmccart
Jun 12, 2007 02:12 PM
andyr354
Aug 15, 2006 11:05 AM
LCH
Jan 8, 2006 06:10 PM
