high engine temp ?
Old 09-18-2005, 12:15 PM
codered's Avatar
high engine temp ?
my first time pulling a camper in the mountains this weekend and i was getting concerned with my engine temps once i started uphill the temps climbed to 210-215 degrees and stayed there. my egt's stayed around 1000-1100 degrees. should i be worried or is this normal. by the way i turned my juice box to the stock mode
Old 09-18-2005, 12:50 PM
Hounddog's Avatar
Normal on long hard pull
Old 09-19-2005, 02:43 PM
1tuffdiesel's Avatar
Yep...completely normal.
Karl
Old 09-19-2005, 02:58 PM
bigblock2stroke's Avatar
The fan doesn't come on for coolant temps until 215deg. Engine designed to run at 230 without issue.
Old 09-19-2005, 08:57 PM
kelley15's Avatar
I dont like that high of a temperature. Put a 180 degree t-stat in from Cummins. Runs cooler now. Hopefully the transmission will like the cooler temps and last a little longer.
Old 09-19-2005, 08:59 PM
Dodgezilla's Avatar
Turn the A/C on and the fan will come on. That will keep the temps down some...
schamran
10-29-2013 07:06 PM
MossyOakCTD
19
12-28-2010 09:11 PM
cwrhnr
05-19-2009 05:18 PM
Racing_Joe66
06-12-2007 05:06 AM
firesine
11-24-2005 10:58 AM
Quick Reply: high engine temp ?
