High Egts All Of A Sudden
Old Dec 25, 2007 | 05:58 PM
JOECUMNS's Avatar
All of a sudden I noticed my EGTS out the roof, not pulling normal driving 60-70 mph range 1200-1400 egts back off throttle to get to 1000-1200. Even at a red light not getting below 1000 !!!! Engine temp gauge good, visual good
any ideas ?????????????????????????????????????[
Old Dec 25, 2007 | 06:00 PM
Hounddog's Avatar
Some one else just recently posted same complaint.His ended being something wrong with the gauge amp.Other post was recent and I think it was on this site.Look for it.It had some checkes listed etc. Opps that thread is on TDR!
Old Dec 25, 2007 | 06:24 PM
bigwheels94's Avatar
Pull the thermocouple out, & inspect it for damage. Replace it with a known good one, & see what it does then. If still high check the same on the guage itself.
Old Dec 25, 2007 | 06:34 PM
Hounddog's Avatar
The thread I was refering to had a milivolt check.
Old Dec 25, 2007 | 06:38 PM
omaharam's Avatar
Most likely the probe and there is not way to visually tell.
Old Dec 25, 2007 | 06:51 PM
vzdude's Avatar
DTR's 'Go to Guy'
If the truck is not pulling like it used to, it could be as simple as a plugged air filter, fuel filter. Or could it be going thru a regen? You don't have your engine listed......
Old Dec 25, 2007 | 07:13 PM
06CTDforAU's Avatar
Since his sig says "Turbo back with Magnaflow straight thru muffler w/6" tip" I'm guessing that he has a 5.9L Cummins. At least that's what I would suspect. I'm guessing that it is your probe if the truck feels fine.
Old Dec 25, 2007 | 08:51 PM
vzdude's Avatar
DTR's 'Go to Guy'
Originally Posted by JOECUMNS
, not pulling normal driving 60-70 mph range[
That's all I was going by.
Old Dec 25, 2007 | 08:56 PM
06CTDforAU's Avatar
Good point. I missed that I guess. It's easier to just list the engine, huh?
Old Dec 26, 2007 | 07:28 AM
JOECUMNS's Avatar
Sorry, I'll update my sig. It is 07 5.9 engine.
Old Dec 26, 2007 | 08:57 AM
vzdude's Avatar
DTR's 'Go to Guy'
Yeah......defiantely check for codes, and double check filters. Even with clogged filters, the egt should go down at a stoplight. Sounds like if everything else checks o.k., probably a bad probe or guage. What does the egt guage read when the ignition is turned on, but the truck isn not running? That would be a big clue to a guage problem.
Old Dec 26, 2007 | 04:16 PM
bluebull's Avatar
If your trucks feels like it's down on power check your intercooler boots. They could be torn or just come loose. Check your boost pressure.
madhat
22
Mar 22, 2008 08:46 AM
lgp9999
Sep 8, 2007 11:19 PM
dodgerdog
34
May 18, 2005 08:43 AM
92DIESEL
Dec 22, 2004 09:09 AM
BCarmicle
Sep 22, 2004 12:10 PM
