Help Needed; leaking anti-freeze
Old Oct 16, 2007 | 12:47 AM
gRahAM Diesel's Avatar
In the last week I have noticed what appears to be antifreeze leaking from the engine bay (obviously). It looks like it is coming from a coupling on a coolant line just between the turbo and the block. The line is black but the coupling appears to be a silver non-ribbed flex with hose clamps on both ends. Both hose clamps are good-in-tight. It only leaks when parked on an incline. Does anyone know what the coupler is and is it a common issue? It is still under warranty so it should be covered, just dont want to give up the 2 days sitting at the dealer.
Thanks,
Judson
Old Oct 16, 2007 | 12:50 AM
53 willys's Avatar
mine leaked as well..but I just snugged the hose clamps up and mine quit leaking.
EDIT
maybe try snugging the hose clamps with a nutdriver or 1/4" ratchet and socket
Old Oct 16, 2007 | 06:06 AM
millco's Avatar
That was the fix for mine as well a while back!! It hasn't leaked since!
Dan
Old Oct 16, 2007 | 08:43 AM
Norm01's Avatar
This is a common issue with 06 trucks. Loosen clamps, rotate them a little and re-tighten. Problem fixed.
Old Oct 16, 2007 | 02:44 PM
shep1's Avatar
I tried to tighten mine as it just started to leak a little. I can't seem to get to the clamps with any thing to tighten them. Anybody know the size and any tricks or special tool to get to them.
Old Oct 16, 2007 | 03:32 PM
RMCBRIDE's Avatar
Collant Leak
I just posted the other day about this leak. If you go to the search function and put in Coolant Leak it will bring it up. You will get some pictures and where the leak is located. I can not remeber the wrench size, but it was a SAE size.
Old Oct 16, 2007 | 09:29 PM
53 willys's Avatar
hose clamps are 5/16" nutdriver or socket
Old Oct 16, 2007 | 09:39 PM
scootertrash35's Avatar
hose is part #05179114AB $15 at dealer if you can't get it to stop leaking
Old Oct 16, 2007 | 09:47 PM
wreedCTD's Avatar
can someone post a pic of the coupler where the leak occurs? i want to make sure mine is tight.
Old Oct 17, 2007 | 01:35 PM
Thanks for the replies fellers. The hose clamps are really tight; i will take the suggestion of loosening and repositioning to see if that helps.
Old Oct 17, 2007 | 01:37 PM
Our camera is on the fritz, but if you look down between the turbo and the block, back near the firewall, you will see the silver sleeve w/2 hose clamps. You have to be pretty much over the top looking down to see it.
Old Oct 17, 2007 | 03:07 PM
https://www.dieseltruckresource.com/...d.php?t=173548
Old Oct 17, 2007 | 06:04 PM
MOJO1's Avatar
Mine to, That really BITES on a new truck! But i still love my truck
Old Oct 17, 2007 | 10:56 PM
Seeder's Avatar
Mine leaked as well, I think this was common on the 06 ers. I swung mine by the dealer and they quicked did it while I waited. Good luck-Frog
broncobilly
Sep 9, 2008 11:37 PM
JP-4.5
Nov 25, 2007 07:39 PM
Lyall
Sep 7, 2006 06:38 AM
screaminbanana
Jun 2, 2005 07:51 PM
Mark Thomas
Jul 17, 2003 07:27 PM
