Headlight Gone Bad
Old 04-28-2011, 05:19 PM
kencan2's Avatar
Headlight Gone Bad
The passenger headlight and parking light does not work, bulbs have checked and are good and the blinker still works. The driver side works fine. 2003, 2500
Old 04-28-2011, 05:20 PM
cbrahs's Avatar
what are you driving?
Old 04-28-2011, 05:21 PM
IPDiesel's Avatar
did you check the fuses? the fuse box has fuses for the drivers side and passengers side seprately. They are the 10amp mini spade fuses in the fuse box under the hood.
Old 04-28-2011, 05:31 PM
kencan2's Avatar
all fuses have checked and are good
Old 04-28-2011, 05:32 PM
IPDiesel's Avatar
Did ya put a meter on the plug of the lights-not just checking to see if the elements were good?
kencan2's Avatar
2003 ram 2500
Old 04-28-2011, 05:33 PM
kencan2's Avatar
fuse meter it showed green on all them
Old 04-28-2011, 06:17 PM
cbrahs's Avatar
check grounds on that side of the truck. bad ground will play havoc on things
Old 04-28-2011, 09:22 PM
kencan2's Avatar
i will check grounds in the morning
thanks
Old 05-08-2011, 09:52 PM
kencan2's Avatar
Thanks for all yalls help, It was a ground wire, Many Thanks
arroyojim
48
09-09-2016 09:43 AM
cbrahs
11-01-2011 11:00 AM
TAMU
05-27-2009 06:34 PM
TAMU
04-27-2009 11:26 AM
3500Dooly
23
06-08-2006 10:21 PM
Quick Reply: Headlight Gone Bad
