Having problems with my shifting
Old 03-30-2006, 01:09 PM
Czapla44's Avatar
I have a 2003 6speed and when you wrap it up to about 2500 rpms and go to shift the rpms increase when you push the clutch in........yes im letting off the accelerator anyone out there ever had that problem or might know what it is please let me know
Old 03-30-2006, 02:27 PM
06inferno's Avatar
has it always done it or just started acting up??
Old 03-30-2006, 04:28 PM
Czapla44's Avatar
pretty much after i put the chip in it so then i changed chips and it is still doing it
Old 03-30-2006, 06:31 PM
hawkeye759's Avatar
Sounds like engine overspeed due to clutch disengagement. Do the rpms continue to climb after clutch is disengaged or does it just do it momentarally. I've noticed on mine, if I load it up and quick shift it will rev up slightly and then drop back down when I depress the clutch to shift.
Old 03-30-2006, 06:52 PM
rammtuff's Avatar
Timing (yer feet ) Let off the go pedal just a fraction before disengaging the clutch. You can jam it into the next gear alot easier and faster this way. If I don't do this I shift it like a dork. Then I get in my wife's car and got to relearn again. This was discussed earlier and something to do with the HPCR and emissions.
Old 03-30-2006, 07:14 PM
texaspower19's Avatar
mine does it every time if im into it. i thought my dad was going to blow it up when i told him to get on it.you just gota drop it in gear fast.
Krob
04-15-2008 09:55 PM
Brendan
10-17-2007 11:12 AM
Czapla44
03-30-2006 06:48 PM
98 Ram 24V
12-24-2005 10:19 AM
94ramtdr
11-29-2002 06:22 AM
Quick Reply: Having problems with my shifting
