Having problems with my shifting
Old Mar 30, 2006 | 01:09 PM
Czapla44's Avatar
I have a 2003 6speed and when you wrap it up to about 2500 rpms and go to shift the rpms increase when you push the clutch in........yes im letting off the accelerator anyone out there ever had that problem or might know what it is please let me know
Old Mar 30, 2006 | 02:27 PM
06inferno's Avatar
has it always done it or just started acting up??
Old Mar 30, 2006 | 04:28 PM
Czapla44's Avatar
pretty much after i put the chip in it so then i changed chips and it is still doing it
Old Mar 30, 2006 | 06:31 PM
hawkeye759's Avatar
Sounds like engine overspeed due to clutch disengagement. Do the rpms continue to climb after clutch is disengaged or does it just do it momentarally. I've noticed on mine, if I load it up and quick shift it will rev up slightly and then drop back down when I depress the clutch to shift.
Old Mar 30, 2006 | 06:52 PM
rammtuff's Avatar
Timing (yer feet ) Let off the go pedal just a fraction before disengaging the clutch. You can jam it into the next gear alot easier and faster this way. If I don't do this I shift it like a dork. Then I get in my wife's car and got to relearn again. This was discussed earlier and something to do with the HPCR and emissions.
Old Mar 30, 2006 | 07:14 PM
texaspower19's Avatar
mine does it every time if im into it. i thought my dad was going to blow it up when i told him to get on it.you just gota drop it in gear fast.
Krob
Apr 15, 2008 09:55 PM
Brendan
Oct 17, 2007 11:12 AM
Czapla44
Mar 30, 2006 06:48 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
94ramtdr
Nov 29, 2002 06:22 AM
