Guess what came in the mail today!!!
hey guys went to my house and looked in living room and there was a set of wicked desel twins for me on the floor.....sweet all the pipeing looks sweet plus manifold and etc will be putting them on tomorrow and sunday i will take pics of the install.
heres some updated photos the mounting brackets are a b---- to mount ill get some pics of that tomorrow..the heater hoses are close even if u bend them probally 1/4 to half inch at most.... will post more tomorrow..
Stock Turbo: For the stock turbo u have to drill out the top two holes so that the studs will clear them( 3/8 ich drill bit). Also the outlet for the stock turbo needs to be clocked around to 7 for the tube(charge air tube) to fit good.
Front drain tube: Due that before you put the turbo in( just makes it easier to get to). Also the oil line that you get is a wee bit short probally an inch, but no biggy what i did was uses the metal sleeve from the back drain plug along with ruber hose that was there for the stock turbo and moved that to the front which gave me the extra length that i needed.
Heater hoses: You are going to have to bend the hoses an inch. Pretty easy to do just make sure you dont bend it to far and put a kink in the hose. Also you have to cut the" L" shaped bracket that hold the heater hoses to the manifold unless you want to take apart your entire heater lines.
Tranny dip stick: You will have to bend that a little as well toward the passenger side about a .5 to 1 ich to get enough clearence.
Mounting bracket for the bottom Turbo: It is best to mount that on the turbo first before putting it in along with the oil drain tube. Because
when u lower the turbo in the truck it is really hard to get all that aligned at the same time so it is easier to do it outside truck then just lower it in. You will need two people to help mount bracket to block one to hold the turbo and brackets and the other to put in the bolt into the bottom of motor.
Hey guys here some vids of the spooling of the twins...one vid is while doing 65mph on freeway the others at night from stand still.
http://s1023.photobucket.com/albums/...ent=boost3.flv
http://s1023.photobucket.com/albums/...rent=boost.flv
http://s1023.photobucket.com/albums/...ent=boost2.flv
Stock studs? Max boost Max EGT's
Are you running on the stock studs? Looks like Max boost is comming in at 50-52 or so. Thats on stock injectors right? What are your cruising and Max EGT's looking like?
I sure would like to do something similar
Ya its stock studs..and as far as i know stock sticks..also when it hits overdrive and the TC locks up it pops up to 60 psi but dont like running that high of boost on stock studs..lol
ya i will get some tomorow for you.It took me by myself 2 days from 830 am to about 6pm both days second day my buddy came over and he snapped one of clamps so order a new one cost like 50 bucks all good though..here some more vids for you guys one of speedo and one of temps.. both were at standstill then hammered on it till hit like 50 to 55 psi.
http://s1023.photobucket.com/albums/...rrent=temp.flv
http://s1023.photobucket.com/albums/...rent=speed.flv
Here some pictures of it all together.
http://i1023.photobucket.com/albums/...00309-1018.jpg
http://i1023.photobucket.com/albums/...00309-1020.jpg
http://i1023.photobucket.com/albums/...00309-1019.jpg
