Guages in pillar mount
Old 04-11-2006, 09:55 PM
BobQ's Avatar
When I put my guages in my pillar mount, they were loose, so I put electrical tape around them to snug them up. Now that is getting warm, the tape is moving, is there a better way? I also have a guage on the steering colume that is doing the same thing?
Thanks Bob
Old 04-12-2006, 12:07 AM
dodgeramrod's Avatar
Have you tried using the bolt up back part of the gauge? I think that is what holds it in place if it doesnt fit tight. Mine were tight so i didnt have to use anything. Someone will chim in.
Jim
Old 04-12-2006, 07:43 AM
BobQ's Avatar
I tried the back part but it is too wide, I think the only way is by friction. I originally had a Banks kit and they told me to sand the holes with sand paper to make the guages fit tight, now the isspros' are too loose. The electrical tape worked well, it just doesn't like the heat.
Has anyone else had this problem?
Bob
Old 04-12-2006, 08:29 AM
RowJ's Avatar
Try small strips of black Duck Tape. Holds better in higher temps. I've had same problem with elec. tape in other applications. Duck tape fixes anything
RJ
BarryG's Avatar
Yes I switched from electrical tape to duct tape. Seemed to tolerate the heat better. Since it was thicker I did not have to go all the way around on mine and I left it wide enough so that it extended past the rear of the gauge about an 1/8 inch and sort of folded it over the back so that when I slid it in it couldn't catch the edge of the tape and move it while sliding it in.
chw
12-25-2006 04:30 PM
ataboy9026
03-08-2006 02:21 PM
Seeder
02-13-2006 11:42 AM
Geico266
30
07-29-2004 03:59 PM
thumper 549
10-05-2003 08:16 PM
Quick Reply: Guages in pillar mount
