guages HELP!!!!
Old May 2, 2007 | 11:07 PM
93beater's Avatar
guages HELP!!!!
ok heres where ill start, i have the ip tweaked and im runnign blind , i kno i kno stupid, but im getting my pyro installed really soon just bought it and having my friends shop do it for me, what other guages am i going to need <manditory ones only>! thanks
Old May 2, 2007 | 11:36 PM
BearKiller's Avatar
1.Pyrometer
2.Fuel-pressure
3.Water-temperature
4.Oil-pressure
5.Boost
6.Vacuum
7.Tachometer
8.Fuel-level
9.Speedometer
10.Transmission-temperature
11.Rear-differential-temperature
12.Thermometer sticking in the A/C vent
13.Clock
14.Compass
15.Voltage
16.Financeometer
Old May 3, 2007 | 12:02 AM
np205's Avatar
I wish my Financeometer would go up once in a while, or just stay up and let me play.
Old May 3, 2007 | 02:26 AM
bgilbert's Avatar
Pyro and 60psi boost only.
Old May 3, 2007 | 09:40 AM
93beater's Avatar
i was told a pyro and trans since i pull a lot, what about a boost?
Old May 3, 2007 | 10:48 AM
Cowboy_Customs's Avatar
Sence you tow alot, a pyro, and trans temp are manditory. A boost guage is both fun, and a good idea because, it'll help clue you in on turbo health, and if u have a boost leak. With our IP's having the capability of drawing its own fuel, it can be hard to spot a dead lift pump, so a fuel pressure guage is a manditory item.
I would put them in this order
1)pyro
2)trans temp
3)boost
4)fuel pressure
5)rear diff temp
6)oil temp
7)oil pressure
Old May 3, 2007 | 12:52 PM
93beater's Avatar
sounds like a plan, thanks!
Old Jul 6, 2007 | 04:37 PM
snowmanx's Avatar
How do you fit all those guages in? I'm thinking about a smarty box, so I would need a pyro, trans temp, and fuel pressure. I think I coulds do away with the reat couldn't I?
Thanks for any input.
Old Jul 6, 2007 | 07:19 PM
edwinsmith's Avatar
I think it's best just to line them up across the top of the dash. A lot of guys like the pillar mounts but I think they're tacky.
I have a Tach, boost and pyro on top of the dash just to the right of center and I think they're purty.
Old Jul 7, 2007 | 07:56 AM
Ace's Avatar
Ace
I needed that spot for the garage door opener. There's alot of empty space around the column, not to mention on the floor, if you're creative about fabbing your own mounts:
http://72.19.150.167/PhotoAlbum/Cars/Pics/CTD_81.jpg
I think there's room for one more. Just can't decide what else needs monitoring.
Old Jul 7, 2007 | 02:48 PM
gomerpile's Avatar
1)pyro
2)trans temp
3)boost
4)fuel pressure
5)rear diff temp
6)oil temp
7)oil pressure
how is the best way to tap into the fuel system to get the reading. i want something quick and easy, preferably no drilling/tapping
Old Jul 7, 2007 | 03:48 PM
Ace's Avatar
Ace
Get a tapped banjo bolt from Genos and use it to replace the post filter connection. Then just thread in a line to your setup of choice. With/w-o snubber, isolator, in-cab or under-hood, just about anything that reads up to around 15 or 20 psi mechanical will work.
Old Jul 7, 2007 | 08:10 PM
bigragu's Avatar
How about the 2 guage A pillar pod from geno's made for the 1st gen, mounted on the plastic trim above the drivers window. The contour is close, and when mounted along with a dual and single pod combined on the A pillar, you have a very good line of sight on all 5 guages. Oh, yeah, get the steering column single guage pod for the tachometer, for a total of 6 guages. Do it the correct way by painting the pods to match interior color trim, too.
Old Jul 8, 2007 | 05:20 AM
KRB's Avatar
KRB
1)pyro
2)trans temp
3)boost
4)fuel pressure
5)rear diff temp
6)oil temp
7)oil pressure
OK, so now you have me wanting a fuel pressure guage . Is this something that needs to be monitored ocassioanlly all across the power band like oil pressure or can it be mounted under the hood and just checked at idle like when checking trans fluid etc?
Since you have an auto, I'd move that temp guage up to #2 as well IF you plan on towing anything. OR take it out of OD when you do. It can creep up there on you
Old Jul 8, 2007 | 07:18 AM
You won't see a drop until there's a major problem if the gauge is under the hood. The nice thing about an in-cab gauge is you know when the filter is due for a change instead of guessing. My filter's been on for nearly a year and it's still doing well.
bogie418
16
Oct 3, 2005 03:22 PM
robox
Sep 2, 2005 02:01 AM
dsl-nut
Jun 18, 2003 11:52 AM
Oct 8, 2002 06:52 AM
