got my first oil analysis
Old 11-12-2009, 11:34 PM
hotrod929's Avatar
What do you guys think? They say not to worry about the brass/bronze content. Im not really that impressed with the length of time I got on the Amsoil. They said to change in the next 2k miles which only gives me 9k out of an oil change with two filters. Im thinking of switching to Valvoline Premium Blue because it is available local for a good price. Thanks for all the help
HotRod
File Type: pdf
Old 11-13-2009, 04:53 AM
sabersix's Avatar
You didn't say how many total miles are on the engine.
The oil is still strong (8.2 TBN) and could go a lot longer than 2K more miles. I think Blackstone is recommending the oil change to establish a baseline of readings for your engine. Once you have two or three good reports, you'll be able to extend the change interval with confidence. Amsoil is good oil for long intervals, but only worth the cost if your going to run it for extended intervals. I run the Valvoline Premium Blue since it is less expensive and I'm changing my oil according to my truck's computer (i.e. less than 7,500 miles).
Old 11-13-2009, 12:45 PM
hotrod929's Avatar
63000 on the truck today.
HotRod
Old 11-13-2009, 04:11 PM
trik396's Avatar
Do you have studs installed in the head?
Reason I ask is the lube used by ARP that they supply has copper in it and it really showed up on my reports for awhile.
Old 11-13-2009, 05:20 PM
surfram's Avatar
Silicon of 3 looks great. What brand of air filter are you running?
Old 11-13-2009, 05:45 PM
Hvytrkmech's Avatar
How did you capture your sample?
Old 11-13-2009, 07:08 PM
hotrod929's Avatar
I use the amsoil filter recomeded for the ****** whistler.
No head studs.
Took the sample out of filter with a turkey baster and changed the filter.
Hotrod
Old 11-13-2009, 07:27 PM
Hvytrkmech's Avatar
That may be part of your problem with the higher copper #s. The rest of your wear numbers look good. I would go to 10k on the oil, then resample and change it just to establish a good base line. Then extend service intervals accordingly.
All oil samples should be captured with with the engine and oil at full operating temp. This allows for a real world sample with contaminates still suspended equally in the oil. You should also capture it from either a mid point drain when changing the oil, or drawn from the dipstick tube with a vacuum pump. (the preferred method) If you decide to continue with the method you are using, at least make sure the engine and oil temps are up as previously stated.
I just bumped my oil change interval to 12,500 mi and I am not even using synthetic oil.
Old 11-13-2009, 08:09 PM
hotrod929's Avatar
The engine was fully warm when I did it. But you are right that might be the reason for the copper. I am going to go to valvoline blue in 2k miles cus its bunches cheaper and easier to get and then go from there. Thanks for all the help.
Hotrod
Old 11-13-2009, 08:14 PM
Stbentoak's Avatar
Can you switch back and forth between DINO and SYN with no adverse effect? I thought once you went syn you needed to stay that way... any logic in that?
Old 11-13-2009, 08:21 PM
Lost Lake's Avatar
Your moly is really low.... I get better readings running Delo....
My silicon is always 3 or 4 running a stock filter....
Old 11-13-2009, 11:46 PM
hotrod929's Avatar
I didnt even think about that. I am using the Amsoil 15-40 Marine oil I didnt know that it was a full synthetic. Im not sure though. Do you guys think Ill have a problem going to Valvoline Premium Blue from using the Amsoil. I just cant afford it right now. Thanks
HotRod
Old 11-14-2009, 01:46 AM
trik396's Avatar
no problems going back and forth from synthetic to dino oil. I don't agree that the way you sampled your oil has anything to do with your copper readings.
Old 11-15-2009, 03:41 PM
Thundercraft's Avatar
That's because Delo needs molybdenum. Not required in a "real" synthetic. There's some trace amounts from his old oil.... that's why the low reading.
Old 11-15-2009, 03:43 PM
no problems in switching back and forth.
I'm not so sure that I agree that the sample method was at fault (maybe if the silicon reading was really high....).
Regardless of what you change you, I would pull another sample (try a "cleaner" method if you can) when you change that oil out and see what the copper is up to.
chaikwa
06-27-2011 11:47 PM
rraulston
07-16-2010 02:19 PM
Mocho
11-21-2009 03:44 PM
PRO-NRA
08-18-2009 09:39 PM
jrs_dodge_diesel
08-15-2007 02:23 PM
Quick Reply: got my first oil analysis
