Getrag Parts and Clutch Recommendations needed
Old 11-19-2010, 05:08 PM
Overdrive440's Avatar
My 1992 W250's getrag just starting having bearing noises, so I'll likely be peeling it apart soon.
I've looked and searched, but I'm not sure where to get a rebuild kit. I've ordered a kit online for a mopar 4-speed, and got generic unmarked bearings, so I wasn't too pleased. Who's ordered a full kit? from where? and what bearings were in it?
Also, I'm looking for a clutch too while I'm in there, and there's tons of choices for that too, I would like to upgrade, but don't need anything crazy like ceramic pucks. This is for a daily driver type truck, with some car hauling thrown in for fun.
Old 11-19-2010, 05:22 PM
G1625S's Avatar
Call Peter at South Bend for a clutch. You won't be disappointed. I got my getrag parts through a local big truck parts house (fleet Pride) but there are lots of options on that end. While bearing quality is important, I believe setup of the Getrag is paramount. I used cheap bearings in my build and tried to pay close attention to the setup and it ran well at about 280rwhp for a long time.
edit--welcome to DTR
Old 11-19-2010, 06:22 PM
freight train's Avatar
If the motor is primarily stock the factory Sachs 13" clutch is a good one. Many will agree with me but my hole family have used them and we tow. Alot! Mine had 140k on it and the only reason I installed a new one is because the RB was so loud it drove me crazy. The clutch still had life on it. Just my opinion though. I think the money for a Luk or SB is a little much for a stock motor.
Old 11-19-2010, 07:41 PM
zbag.com has the Getrag parts.
Old 11-20-2010, 12:04 AM
Best Paint (Getrag category)
pulltilbroke's Avatar
Yep, Zumbrota, Blumenthals or TBtrans will have good bearings in there kits.
What hp level are you at or whats your goal?
The stock Sachs will hold some good power.
Old 11-20-2010, 10:33 PM
enydick's Avatar
south bend clutch the only way to go peter and all of the employees there are great and customer service is the best
Old 11-22-2010, 09:43 AM
Power levels are a little more than stock. So far the truck has an HX35 turbo, POD injectors, 3200 rpm governor spring, and a few minor pump adjustments. I might upgrade the fuel pin and add a HT3B turbo or something in the next year or two, so I'm probably needing a bit more than a stock clutch.
Old 11-22-2010, 10:32 AM
MrExtreme's Avatar
You will want to go better than a stock clutch, my truck was about where you are now in power, maybe a little more and 3rd gear heavy throttle would spin right through a new stock clutch. Either Soutbend or Valair will set you up with the clutch you need.
Old 11-22-2010, 11:33 AM
Douglas2's Avatar
hey-Hey!!!,
I put a stock Luk HO clutch behind mine( PN in the sig ). New SB flywheel with a ball pilot bearing and am quite pleased with it. Light pedal and smooooth. Stock power level for that one was 245 hp and 600 lb.-ft; and with light mods I'll not exceed that by much if any.
cheers,
Douglas
nbaggett89
12-26-2015 09:36 AM
Overdrive440
11-25-2010 09:06 PM
bgilbert
01-05-2008 12:03 AM
bucknasty
09-16-2007 08:25 AM
CTD_Neil
07-19-2005 08:13 PM
Quick Reply: Getrag Parts and Clutch Recommendations needed
