what gauges to get
Old 08-27-2007, 07:10 PM
3592788's Avatar
Question what gauges to get
If you had 6 spots to fill up what guages would you get? So far i have autometer phantoms which are a boost, tranny, pryo, and air gauge. I need to get two more and dont know which ones to get so what do you think
Old 08-27-2007, 07:25 PM
DTR 1st Sergeant
soulezoo's Avatar
I would say definitely fuel pressure and rail pressure-- if possible. Don't think autometer can help you with the rail though. DiPricol make a gauge that is close to the phantom for the rail IIRC.
If you were like me, and had twin turbos, you could have another boost gauge in the cold pipe between turbos You know like the commercial, double your pleasure and double your fun!!
Old 08-27-2007, 07:31 PM
Dodge359's Avatar
Fuel pressure and rail pressure or Fuel pressure and drive pressure.
Old 08-27-2007, 07:37 PM
3592788's Avatar
What would the fuel pressure gauge read from or which one do i need 0-? and what is drive pressure thanks
Old 08-27-2007, 07:38 PM
DTR's 'Go to Guy'
vzdude's Avatar
OIL PRESSURE is a must! The factory unit is a guestimate at best. It is a calculated figure determined by engine temp and time running. Mine reads low cold, low hot and high at hot idle. Not very dependable! Autometer phantom was my choice as well!
Old 08-27-2007, 07:42 PM
Dodge359's Avatar
I dont know how high the fuel pressure is, I guess it would depend on the pump. A drive pressure gauge lets you know how much back pressure you are generating in the exhaust manifold. Kinda like a boost gauge and you use it to try and stay ahead of a popped head gasket and/or charger.
Old 08-27-2007, 07:43 PM
3592788's Avatar
Does autometer phantom make a drive pressure gauge and if so what is it called thanks
Old 08-27-2007, 07:54 PM
Dodge359's Avatar
I dont know if they do or not. I am getting ready to buy/build one myself. I dont know if there is a specific gauge for it or not. If there is it would be called either a drive pressure gauge or a back pressure gauge. I havent seen one for sale yet but I havent looked real hard either. I think a boost gauge with an isolator would work but I am not sure. I will let you know and hopefully someone smarter than me will chime in here.
Old 08-27-2007, 07:55 PM
Rpainter's Avatar
oil pressure for sure and a rail pressure if you go big on mods if not a fuel pressure gauge easy way to tell time to change fuel filter
Old 08-27-2007, 07:57 PM
3592788's Avatar
So if i get a fuel pressuer gauge what size should i get, 0 to 30
Old 08-27-2007, 07:58 PM
Rpainter's Avatar
I bought a 7 color electric fuel pressure gauge 0-100 psi for 51.00 brand new with sending unit love it
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
Duckman1993
09-12-2006 07:50 PM
AggiePhil
01-30-2005 01:15 PM
Quick Reply: what gauges to get
