Fuel water separater
Old Feb 12, 2005 | 10:14 AM
PZM123's Avatar
Anyone come up with an easy & clean way to run off & catch your fuel into a container so you can see if you have water in the fuel, without laying on your back or dumping it all over a gas station parking lot?
Old Feb 12, 2005 | 10:34 AM
JohnnyH's Avatar
I think someone extended the hose so it is more accesable. It is a bit diffucult getting a bottle up between the axle and steering linkage the way it came from the factory. I use a poland spring water bottle. 16oz I think.
Old Feb 12, 2005 | 01:23 PM
Hemi Cat's Avatar
Extend the hose to make it more accessable or use a drain pan with a 2 ft funnel.
Old Feb 12, 2005 | 06:59 PM
Welder's Avatar
Extend hose down along frame behind front bumper, hangs down about 2" below bumper.
Old Feb 12, 2005 | 08:37 PM
larryt's Avatar
If you don't need for the extension to be permanent you can use a section
of old water hose ( 5/8" I.D. works), 20-22" long should do it.
When done, thow the hose in the toolbox.
Old Feb 13, 2005 | 03:20 PM
Mark Thomas's Avatar
I went to Petco, they have clear tube that is exactly the same as whats on our trucks. I extended mine down far enough to put a glass under it and drain it into it to get a fuel sample.
Old Feb 13, 2005 | 06:16 PM
AaronT's Avatar
I just slip a clear soda bottle down, slip the drain tube into it and it rests against rear of front diff. Did not add any length to tubing, maybe mine came longer.
Another option is the wifey can lay under the truck to catch the stuff, but have not tried this one yet.
dodge350c
Nov 6, 2013 04:18 PM
ZPOD
18
Sep 23, 2010 10:37 AM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
Gene Peterson
Jan 7, 2006 02:32 PM
