Fuel system rebuild
Old May 5, 2011 | 07:56 PM
mhuppertz's Avatar
Fuel system rebuild
Well, I got the tank and the fuel sending unit out, no dirt in the screen, but the bottom of the screen is torn and the plastic is broken.
If I am running a nice big replaceable filter right outside the tank do I even need to worry about the screen, or should I try to fix it?
I am a little worried about running without one....
Also, because the screen is not clogged, I must have a suction leak or a problem upstream like an LP issue.... I'm replacing the puckup tube (thanks DTS sticky) and all of the plastic line from the tank to the lp with metal.
Old May 6, 2011 | 02:23 AM
Bogie's Avatar
if your running proper filtration I would not worry about the in tank screen.
RiverRat2
Oct 15, 2019 10:59 AM
wiskeyVI
13
Mar 20, 2012 10:23 AM
mhuppertz
May 8, 2011 04:43 PM
csa
Apr 2, 2011 09:14 AM
