Fuel Pump turn up
Old Jan 2, 2011 | 11:27 PM
Farmboy12357's Avatar
Fuel Pump turn up
When I turn in the Fuel Screw for more power, the Idle goes up with it. How do I turn the Idle back down?
Old Jan 3, 2011 | 01:39 AM
Onemoparnut's Avatar
There is an idle adjustment screw between the head and the afc housing on top of the injection pump.
Old Jan 3, 2011 | 02:10 AM
Lucas1's Avatar
you have reached your limit for dumb questions today. look in the sticky.....get reading
Old Jan 3, 2011 | 01:11 PM
jimbo486's Avatar
Easy Lucas, he only has 6 posts. Maybe you know the guy but, we've all been there before.
Farmboy, you can use a small punch and a hammer to break the jam nut loose on the idle adjust screw. Just as Bill said, it's between the head and the AFC housing. In the following picture, you'll see it above the fuel screw that you turned up.
Old Jan 3, 2011 | 03:14 PM
Lucas1's Avatar
if you cant figure out how to adjust the idle once you have turned your pump up you SHOULDN'T be messing with your pump.period.
farmboy get in the sticky and read for two weeks then ask questions
Old Jan 3, 2011 | 04:07 PM
jimbo486's Avatar
Give him the benefit of the doubt. Maybe some people just don't have that kind of time. Sometimes they may just be looking for a quick answer just to get by at that particular moment. We've all been there, having to ask the simplest of questions sometimes.
Farmboy, do you have gauges in the truck? Specifically, EGT and boost? Give us some more info about the truck and what you have done to it.
Old Jan 3, 2011 | 05:45 PM
huntinguy's Avatar
You think this is bad? You should go over to Pirate, that place is harsh.
Old Jan 3, 2011 | 06:35 PM
MARF75's Avatar
You ain't just whistlin dixie!!
Old Jan 3, 2011 | 06:52 PM
I know that these are stupid questions. I figured that if I ask a simple question, then I can get a simple answer. I always worry that if i mess with my truck then it won't run right or something. haha
Old Jan 3, 2011 | 07:17 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
off topic but pirate is so bad its ruins the entire site. its almost pointless to post there.
Old Jan 3, 2011 | 07:45 PM
Lucas1's Avatar
i would never want this site to get like this.
BUT i also expect someone to do a little research ,effort by themselves ..i am the first to help but at least try to help yourself first
READ THE STICKY EVERYTHING YOU NEED TO KNOW IS IN THERE
Old Jan 3, 2011 | 07:48 PM
archer2's Avatar
Maybe somebody needs a nap.
Old Jan 3, 2011 | 08:10 PM
What's "The sticky"??? I've done a bunch of research, or atleast tried to and nothing makes sense to me and I can't find anything!
Old Jan 3, 2011 | 08:12 PM
huntinguy's Avatar
The sticky.
https://www.dieseltruckresource.com/...t-t102027.html
Old Jan 3, 2011 | 08:13 PM
archer2's Avatar
It's the second thread down in this forum
