Fuel Pump turn up
Old Jan 4, 2011 | 02:54 PM
  #31
Farmboy12357's Avatar
What's the l/h side? and PCM? sorry again for the dumb question. the Boise Area
Old Jan 4, 2011 | 03:01 PM
  #32
huntinguy's Avatar
Left hand side. And power train control module.
  #33
raggmann's Avatar
l/h-left hand
PCM -basically the computer inside the l/h fender beside the battery,behind the headlight.
Old Jan 4, 2011 | 03:04 PM
  #34
yeah, I figured it meant left hand about a second after i hit reply. ok, i'll go look for it
Old Jan 4, 2011 | 03:14 PM
  #35
When you say the "3-wire plug", is it under the dash or under the hood?
Old Jan 4, 2011 | 03:28 PM
  #36
ok, I think all the connections are good. I think I just need to replace the Magnets or whatever sensor is on the engine. How do I go about getting to that and replacing it?
Old Jan 4, 2011 | 03:39 PM
  #37
raggmann's Avatar
The 3 wire plug is indide the cab.
As far as the pick-up magnets or whatever.....I'm not sure.
Old Jan 4, 2011 | 03:41 PM
  #38
okay, I can't find the 3 wire plug but all the wires that come off the tach seem to attach to somewhere. I think it's just the magnet pick ups
Old Jan 4, 2011 | 03:42 PM
  #39
huntinguy's Avatar
Your truck will have a CPS crank shaft positoning sensor.
Old Jan 4, 2011 | 03:43 PM
  #40
Where do I find that? I don't know what it looks like
Old Jan 4, 2011 | 03:45 PM
  #41
huntinguy's Avatar
Don't Know my truck doesn't have one.
Old Jan 4, 2011 | 03:48 PM
  #42
okay
Old Jan 4, 2011 | 03:58 PM
  #43
huntinguy's Avatar
I went out to my other truck and found it. It's right betwein the water pump and the crank pully.
Old Jan 4, 2011 | 04:01 PM
  #44
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
.049" gap (plus or minus a couple thou) should be between the sensor and the pulley... might want to check your if its not working.
Old Jan 4, 2011 | 04:05 PM
  #45
is it on the side of the engine and what's it look like?
