fuel pressure guage
Old Mar 8, 2005 | 09:43 PM
hooked3800's Avatar
fuel pressure guage
what is the best location to mount a fuel pressure guage? and is the billet cap from geno's the best place to tap into to read fuel pressure? thanks in advance
Old Mar 8, 2005 | 09:57 PM
deezulsmoke's Avatar
The easy place to install is to get a banjo bolt and install at the pump. The only thing I would not like about tying the fuel pressure gauge into the fuel filter canister top, is that everytime you would need to change your fuel filter, you would have to mess with the fitting and the line that is tapped into the cap.
Old Mar 9, 2005 | 10:48 AM
Mule's Avatar
I just oredered the banjo bolt kit from Geno's and the black Di-Pricol 0-30 gauge. You have to find a conversion from the 1/4" NPT fitting on the gauge kit to the 1/8" NPT fitting on the banjo, but I don't think that's too hard.
The cap mounting didn't make sense to me, I figured there would be too much wear & tear on the seals that way.
I to am interested in where people are mounting their gauges too..... I'm running out of room under the dash, one towing brake setup and an external light switch mount takes up knee room.
Old Mar 9, 2005 | 01:51 PM
Car_nut57's Avatar
The easiest place is the inlet to the pump with a banjo bolt and you will also need an isolator for the mechanical guage to make sure no fuel could ever get in the cab.
Old Mar 9, 2005 | 08:16 PM
metal_miner's Avatar
Here's some pics of my install:
http://www.turbodieselregister.com/u...p?userid=15605
I've since installed a Holley Blue pusher pump.
mytrucksaslug
Dec 16, 2007 01:11 PM
ScottMt02
Jul 27, 2007 07:04 PM
jgiachino
16
Jul 11, 2007 07:33 PM
bigragu
Jan 24, 2006 11:16 AM
Dodgezilla
15
Mar 11, 2003 07:49 AM
