fuel plate 10 vs 11
Old 03-31-2009, 04:57 PM
DTanklage's Avatar
fuel plate 10 vs 11
whats the diff between these two plates?
any way anyone could try to draw the profiles and take pix?
would really appreciate it
thanks in advance
don
Old 04-01-2009, 01:25 PM
DTanklage's Avatar
no one on here has looked at both?
find that hard to believe
Old 04-01-2009, 01:31 PM
Dr. Evil's Avatar
Im not sure about the 11 but you can see a 10 here:
If you dont tow heavy go with the 100.
Old 04-01-2009, 07:14 PM
ShaneTbolt's Avatar
Newbe here, is there a definition or chart that goes with each available fuel plate?
Old 04-01-2009, 08:40 PM
97 D-Tec's Avatar
the difference is the profile. the lower the number the more fuel and more agressivly the fuel comes in as you go through the rpm range. This does also equate to more heat but the potential for more hp if oyu have the air for it.
Old 04-02-2009, 02:57 AM
Tate's Avatar
0 plate FTW!
Old 04-02-2009, 02:55 PM
DTanklage's Avatar
Originally Posted by Dr. Evil
Im not sure about the 11...
i do tow heavy. well, 22,500 pounds combined. used to seem heavy til i started turning this thing up : ) was in tenn and went to mid south diesel to get a plate. i asked for a 10 and dude brought out a 11. i had him go back and get me the 10 w/o looking at the profile of the 11. just curious what the difference is. i take it the 11 is newer and possibly a replacement for the 10? wish i would have looked at the profile...
also, my 10 is not like the one pictured above. well, thats close but it is shaped more like a V (on its side) than the one above which to me looks more like a C
thanks everyone
don
Old 04-02-2009, 03:17 PM
STate's Avatar
Here is a chart to give you an idea of what plate produces what kind of hp and tq numbers
http://www.puredieselpower.com/catal...ate-p-451.html
Old 04-05-2009, 03:30 PM
ShaneTbolt's Avatar
Thank you STate. Now that was very helpful.
Old 04-05-2009, 04:13 PM
DTanklage's Avatar
#11 - 280/680
#10 - 330/750
wow, hard to believe the difference between the two pumps
those are the numbers with a 215 pump
look how much less difference it makes in a 180 pump:
#11 - 210/550
#10 - 220/570
do you think that is accurate???
don
Old 04-05-2009, 07:32 PM
Big Blue24's Avatar
The 215 pumps do make a lot more horsepower with just a plate change. If you mod the AFC, advance the timing, add a Mack plug, etc, the 180 pumps can actually make more power since they don't retard timing like the blasted 215 pumps.
Old 04-12-2009, 10:16 PM
p.o.s.'s Avatar
how many mpg are you losing by installing the #10 plate?
Old 04-13-2009, 01:11 AM
wcbcruzer's Avatar
none......
West Coast
07-01-2007 02:32 PM
plow
07-20-2005 08:40 PM
Rockcrawler
06-23-2005 11:40 AM
banks twinram
02-05-2005 10:38 AM
Quick Reply: fuel plate 10 vs 11
