fuel leaking from bottom of filter
Old Dec 26, 2009 | 06:07 AM
91.5CTDBanks's Avatar
Ever since it got colder I have a fuel leak from the bottom of the fuel filter. After the truck runs a bit it stops. I discussed it with David and I have not got around to doing anything about it. I am going to replace the filter but is there anything I need to look for to fix the leak? Thanks.
Old Dec 26, 2009 | 07:02 AM
Make sure it's not coming from the fuel heater gasket and running down the side of the filter. That is a very common place for these to leak, especially when it gets cold.
If it's leaking from the drain/WIF sensor, you can replace it or you can get a filter that does not use the WIF sensor. Fleetguard 1221 or equivalent.
Old Dec 30, 2009 | 08:37 AM
Where is the best place to get the fuel heater gasket? NAPA or a diesel shop?
Old Dec 30, 2009 | 10:06 AM
dzl_damon's Avatar
Napa didn't have it around me. I had to get it from a diesel shop and he had to order them too. I"m pretty sure it's just an o-ring, but I havn't changed mine yet (I need to)
Old Dec 30, 2009 | 12:09 PM
Alan88's Avatar
Can you go into detail on where the o ring is located and how it needs to be replaced? My truck is also leaking fuel from above the fuel filter!
Old Dec 30, 2009 | 05:19 PM
See this thread:
https://www.dieseltruckresource.com/...r-t258221.html
It's about replacing the whole fuel heater but it has good pics of the o-ring and heater.
mike bibbo
Feb 25, 2011 10:30 AM
pwrtripls1
Apr 30, 2008 01:45 PM
pwrtripls1
Feb 9, 2008 09:15 AM
natlchamp2k4
Jan 15, 2007 10:24 PM
