fuel leak
fuel leak
i have a 1989 power ram 250. i have a significant fuel leak coming from the fuel heater. i have two manuals on this truck but neither show how to remove the fuel heater to replace the gasket. also, is this a dodge only gasket or can i get it at a parts store? any info would be great.
I think Cummins will be your best source for the gasket. Give them your CPL and ESN (located on the data plate near the injection pump and they will get you what you want).
The nipple that the filter mounts on unscrews from the bottom of the filter head, which will allow the heater to drop free. Cummins says to put it back together with loctite and torque it to 24 foot pounds.
Should only take a couple minutes longer than a filter change.
http://www.cspi.cummins.com/na/pages...ampa/index.cfm
Cummins Southeastern Power would be the guys you want. Click on the location closest to you on the map and you will find their address and phone number.
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
