Electrical problems?
Old 01-11-2010, 10:11 PM
Fred the Farmer's Avatar
Hey all,
well i was installing my new isspro elec. fuel pressure guage, and when i was installing it i blew 3 fuses. I later figured out i connected the wires in the connector touching. Thats why i blew the fueses. Well i replaced all my fuses and everything and now my dash pannel is all edit.
When i turn the key on the lights come on. When i leave the key off and pull the light switch it turns the lights and the radio on. I'm all kinds of confused guys.
Any help will be highly appreciated.
Old 01-12-2010, 05:12 PM
freight train's Avatar
Man sorry to hear about your situation. Sounds like you have some melted wires or possibly something else touching each other in your fuse panel. Honestly this is the main reason most guys leave electronics alone. These harnesses are approaching 20yrs old. The dually my dad bought back in the summer had wiring issues. Mostly do to the owner! He installed a keyless entry. In the process he shorted the wire to the door jam switch. This in turn shorted several wires in the headlight switch and associated wires. He used 2 aftermarket switches for the headlights and running lights. Very ugly setup. Not to mention he put them on a plate in front of the AC duct blocking it up. I did some yard hoping and found a 93 d150. Cut all the light wires before they intered the main body of the harness. And one wire at a time wired that plug into my dads truck harness! You need to start with were you were!!! Find out what the 3 links that touched and go threw what they go to. Its going to take time and patients. Good luck.
Old 01-12-2010, 08:07 PM
ok thanks for the help, i will be sure to do that, i may find me a parts truck and just do that
Old 01-12-2010, 09:01 PM
You cant get mad at other members for not chiming in. I am a electric forklift mechanic. I can have 5 Crown reach trucks that have the same problem and have 5 different reasons why its doing it! Thats the hardest problem with electronics. People can only tell you obvious stuff. No one wants to sound like a no it all or sound like they are talking down to you. You have to find a wiring schematic, and be patient. You will figure it out. When you do, post it. Your hard work will help out others in the future.
Old 01-12-2010, 09:17 PM
yes sir, i will be sure to do that when i get my dash apart
Old 01-12-2010, 09:43 PM
It sounds like you have a ground problem, stuff is grounding through the lights.
Old 01-13-2010, 09:16 AM
yep thats what i finally figuered out yesterday but thanks for the help guys
DJ Turbo.
10-13-2011 09:11 PM
David Kee
10-11-2003 08:33 AM
FastSS
09-08-2003 01:47 AM
FastSS
01-08-2003 05:53 PM
TurboAZ
10-11-2002 12:34 AM
Quick Reply: Electrical problems?
