egts and aurora 5000
Old 08-17-2007, 10:52 PM
allisfarmer's Avatar
hey everyone, i've got a problem i just installed my aurora 5000 (i really love it!) but anyway i can peg my egt gauge almost as fast as i did with my stock turbo. I figured my egt problems would be gone with the new turbo but no dice i have a #5 plate full forward ,AFC housing full forward,4000gsk laser cut dv's and stock injectors,stock exhaust manifold and a k&n cone filter i figured i wouldn't be all that hot with stock sticks would bigger injectors cool it down im stumped any help would greatly be appeicated
Old 08-17-2007, 11:18 PM
chrleb1's Avatar
It's too big. You aren't spooling it well enough. Bu the time it is going, you EGT's are way up there. You'd be better off with a 64mm turbo with a 12cm housing.
Old 08-17-2007, 11:48 PM
SPLnut's Avatar
find you some 181 or 191 dv's and ditch the nasty laser cuts and go for a 62 or 64/12 or 14...
Old 08-18-2007, 02:24 AM
WUnderwood's Avatar
I agree with the others, you dont have enough fuel down low. get a smaller turbo or bigger injectors
Old 08-18-2007, 02:47 AM
jwb600's Avatar
I figured the same thing. mine still gets hot also. I thought it would be impossible to get it hot, boy was I wrong
Old 08-18-2007, 07:37 AM
huh............ i've got a ton of fuel down low i guess i will start moving my afc housing to try and find a happy place............this sucks cause i was planning on alot bigger injectors
Old 08-18-2007, 09:12 AM
Olratlr's Avatar
That is what you need is bigger injector's.
Old 08-19-2007, 09:42 PM
chrleb1's Avatar
The problem sometimes can be too much fuel down low.
I've done the whole A5K on a 12 valve. I got sick and tired of it and went to a 64mm turbo. It made jsut as much power and much more driveable.
Get rid of the Laser cuts, go to some Dynomite stage 3 or 4 injectors, and toss in a set of 181 DVs. I can guarantee you will be happier.
12 valves and big turbos don't like each other (unless you are going to lite it with NOS). The A5K is really more the common rail. They are able to spin big turbos easily.
Old 08-19-2007, 11:08 PM
99globalwarmer's Avatar
save it for some twins
Old 08-20-2007, 09:53 AM
aaaahhhh....i'll keep the a5k the truck isn't my everyday driver it's my toy/ pulling truck/take the old lady out on the town /whoop up on some power chokes truck.i'll probably just get some bigger injectors and just put them in for pullin season next year.but i thank a bunch for your advice
Old 08-20-2007, 04:43 PM
1stGen545's Avatar
Thats why ATS dose not recomend over a A3K for daily drivers. The 5 spooles way to slow they have a chart on there site. It takes over 7 seconds to get going.
moolie
11-04-2011 08:44 PM
W1cked
24
01-29-2007 12:00 PM
stock03
13
09-12-2006 08:07 AM
casper_cobra
04-28-2006 09:54 AM
Gwoody
04-02-2005 01:53 AM
Quick Reply: egts and aurora 5000
