edge comp and edge (drag) comp???
Old 06-30-2007, 03:56 PM
mx684's Avatar
what is the differences?? looking in adds i never see the choice between comp or drag comp, it always is just comp....can someone explain the differences to me???
Old 06-30-2007, 04:34 PM
mx684's Avatar
anyone?????
Old 06-30-2007, 04:39 PM
yousoobad's Avatar
Not sure. I have the Edge with attude on mine. Call them, (Edge) they are great for information.
Old 06-30-2007, 04:40 PM
1qckdodge's Avatar
The Drag Comp fuels till 3200 and the regular till 2700, go for the Drag Comp, but the regular is still very potent, some say the Drag version is like 140hp but Edge makes no mention of this( I think).
Old 06-30-2007, 05:12 PM
mx684's Avatar
hmmm...i have looked through many catologs and such and have never seen a "drag" comp listed under edge products...its always just the plain ol comp...but then i see people on here sayin they have a "drag" comp...thats why i was confused...
Old 06-30-2007, 06:16 PM
dieseldork's Avatar
drag comp
I started put with a regular comp and then sent it in to get the drag update and let me tell you there is a big difference .
Old 06-30-2007, 07:07 PM
Big Blue24's Avatar
Drag is a 100 dollar upgrade to the regular edge comp. They don't list it in mags or brochures cause it requires that you fax in a liability waiver that states you are aware that it is for race applications yada yada could cause engine failure yada yada, could blow your tranny.... A drag comp is equal to a Hot Juice w attitude. For the newer versions of the Juice, you simply plug in a code that they give you after your 100 bucks and faxed in waiver forms and then you have a level 6 option called Hot. On the comp module, you actually have to mail in your box and they reprogram the fifth level and turn it into a Drag tune. So in essence you lose the old lesser level five and gain the Drag tune for level five. The drag does not net more peak horsepower, it simply adds fuel sooner in the power curve and fuels as previously stated to 3200 RPM. It is faster cause it gives you more power sooner... has more area under the curve on a dyno sheet so makes more useable power.
Old 07-23-2007, 08:23 PM
mx684's Avatar
oh ok...thanks for explaining that to me...it had me confused. i have looked and looking and all i find is the comp...never seen the drag...i wanted to check into it before i bought one...i already have a new ez on mine, but want to switch to the comp....didnt wanna waste money on a comp then find out for a little more i coulda had a drag comp..thanks for the good explanation!
Old 07-24-2007, 09:49 AM
thellums's Avatar
you know you can trade in that ez and couple hundred bucks for a comp thru edge.
Old 07-24-2007, 10:01 AM
J7 Diesel's Avatar
The part number for a 2000 Truck is ecd2000hot or 01 it is ecd2000ahot 02 is ecd2000bhot. Ask edge about these numbers and you can order one ready from them, so you dont have to send it back and all that bs.
J7
Old 07-24-2007, 11:59 AM
dodgediesel's Avatar
I wonder why my 2001 box has ECD2000A/B Hot??? What does the A/B stand for???
Old 07-24-2007, 01:17 PM
J7 Diesel's Avatar
The new comps for the 01 or 02 canbe used on either. They send an adaptor for each one. Hot or not same deal.
Old 07-24-2007, 05:46 PM
I see, right on!!
Old 07-24-2007, 07:52 PM
mx684's Avatar
ya i would like to just go ahead and get it from them that way....i didnt know they would take tradein;s...ill have to check into that..
13jy831
02-25-2011 07:45 AM
lvmknsmoke..
08-13-2009 10:59 PM
Desert Diesel
07-14-2005 03:34 PM
rockjeep73
03-25-2005 03:34 AM
MoreSmoke
01-07-2004 09:40 PM
Quick Reply: edge comp and edge (drag) comp???
