Dying out - HELP
Old Apr 21, 2009 | 07:35 PM
ziggy's Avatar
Dying out - HELP
Ok, I've got an 04 cummins with a BD TD and an Amsoil drop in. Other than that, it is stock. A couple of weeks ago, the truck randomly died out as if it ran out of fuel. Then it did it 4-5 more times that day. I wondered if it were the BD, so I returned the truck to stock, but then it did it one other time, so I wrote it off as water in the fuel as I had just tanked up.
Well, since I have run out of that fuel and retanked a few times, it has been going well. Today I decide to put the BD back on and a few miles later it does the same thing. The engine sputters a few times as if its running out of fuel then dies. So I pulled over and tried restarting, every time, it just died again. I got the BD and put it to "NO Added Power" and came home fine.
I don't know if these are coincidances (not spelled right I know) or if I have something else going on like a fuel pump. Anyone got any bells ringing after reading this?
Thanks.
Old Apr 21, 2009 | 07:42 PM
Checkmate's Avatar
do ya have a fuel pressure gauge ??
Old Apr 21, 2009 | 07:46 PM
ziggy's Avatar
No sure don't
Old Apr 21, 2009 | 07:53 PM
Checkmate's Avatar
original lift pump ? How many miles?
Old Apr 21, 2009 | 08:00 PM
ziggy's Avatar
As far as the lift pump, I don't know. I bought it just over two years ago. It now has 132k miles
Old Apr 21, 2009 | 09:41 PM
Checkmate's Avatar
Is your pump still on the fuel filter housing ? If so, it's probabaly the original one.
Old Jun 24, 2009 | 07:35 PM
ziggy's Avatar
ok, so I left my TD on stock power and it worked for a while, now I'm letting the truck sit till I get the fuel pressure tested. So that brings me to this question. The dealership didn't want to just do a fuel pressure test (wanted a whole diagnostic), but after reading here and elsewhere online, I'm 99% sure that it is the lift pump. So anyone know of a good pressure testing tool? I looked at Adv Auto, but they don't carry ones for diesel.
Thanks in advance
Old Jun 24, 2009 | 11:42 PM
N.Johnson's Avatar
Why don't you just replace the lift pump with a fass, airdog or what ever. Then get a fuel pressure gauge. Sorry dude, it's really hard to hear your problems and knowing the solution......
Old Jun 25, 2009 | 07:14 AM
ziggy's Avatar
But wouldn't the smart thing to do be testing the fuel pressure to be 100% sure that it is the lift pump before I spend a couple hundred bucks?
Old Jun 26, 2009 | 12:28 AM
N.Johnson's Avatar
The pump craps out and won`t push the fuel volume. If you want a easy way, disconnect the input supply at the cp3 banjo bolt and turn the key on and bump the starter without starting the engine with the fitting in a container. Takes two people to do without making a mess. If the pump is good you should see a volume of fuel fill the container, say about a quart in 30 seconds. But really you got the original pump mounted on the filter housing right. Replace it with aftermarket or get the original from Geno`s (TDR)
Old Jul 1, 2009 | 04:15 PM
ziggy's Avatar
Ok, I've got a fuel pressure testing gauge. Anyone have a pic of where I need to screw it in? I know, I know, but I'm new, humor me
Old Sep 18, 2009 | 08:53 PM
ziggy's Avatar
Just an FYI, changing the lift pump a few weeks back got me cranking again! Thanks!
big_country_001
Nov 30, 2010 07:58 PM
bahama bob
Feb 13, 2008 02:21 PM
Micaiahfied
Mar 18, 2007 09:27 PM
D.T.O.
Jul 27, 2004 07:19 AM
ARAcummins
Sep 15, 2003 04:45 AM
