dropping charge at idle
Old 01-09-2010, 01:52 AM
big stinky's Avatar
When I first bought my truck it used to charge at idle at 14 volts. Now it doesnt charge at all idling. At a stoplight with headlights, blower motor, signal lights, brake lights etc, its sitting at 10v. This happened gradually over 2 years. It does get to about 14 volts at @ 1100-1200 rpms (ear guestimated)
Are these symptoms of a worn out alternator, or a bad voltage reg?
Any input would be greatly appreciated.
Old 01-09-2010, 06:43 AM
JD730's Avatar
Those sound like symptoms of a worn out alternator. My brother's 96 just did the same thing.
Old 01-11-2010, 10:57 PM
Firstgenfanatic's Avatar
Yes, I'm wondering the same thing. My lights get dim when I come to a abrupt stop or when I stop and back up. The volt meter shows 14 or so volts, then drops to 9 or 10 volts. The idle changes and the lights dim. If I give the truck throttle, the voltmeter jumps back up to 14 volts and the lights brighten. Thinking the alternator is getting weak?
Old 01-11-2010, 11:32 PM
jimbo486's Avatar
rebuild the alternator. should normally see 13.6-14v with the engine running.
Old 01-11-2010, 11:49 PM
I have taken alternators apart before, should be a simple changeout of brushes/bearings?
Old 01-12-2010, 10:01 PM
Probably just brushes. If it doesn't feel bad when you spin it the bearings are good to go.
Old 01-12-2010, 11:36 PM
TractorMike's Avatar
Thats definitely an alternator.. I had one go out on my ford truck, Did't really show any signs except the voltage would drop some, Which I thought was normal till I was driving it one day and my battery light came on and then next thing I knew my alternator exploaded.. Now I know what to look for in the future
Old 01-13-2010, 06:53 AM
Trebor's Avatar
[1] Is your idle speed set correctly? [2]Belt & tensioner in good shape? [1]+[2]=Your situation. When I was repairing alternators you would be surprised on how many alternators I received that were in perfect working condition. I had a lot of repeat customers that came back because of honesty.
Old 01-13-2010, 10:29 AM
big stinky's Avatar
My idle speed sounds about the same as all of the rest of the stock trucks I've heard.
And answers to your questions, yes and yes. Both are as they should be. Thanks for the suggestion tho.
Old 01-13-2010, 03:49 PM
97catintenn's Avatar
Why wouldn't it be the external regulator?
Old 01-13-2010, 11:11 PM
rebal's Avatar
try and use compressed air and blow out the alt. real good. I have done this several times with mixed results. some times it starts working better other times nodda
longhauler
12-27-2010 07:24 PM
Travs94Ram
06-16-2008 05:05 PM
Diesel Rover
02-22-2007 03:31 PM
01dodge2500stoc
01-26-2006 10:07 AM
vinny
03-03-2004 01:13 AM
Quick Reply: dropping charge at idle
