do i have a bad fca
Old 06-06-2008, 09:41 PM
adventuris's Avatar
do i have a bad fca
have posted a few times about my somking at idle problem , thought it was turbo seal , replaced turbo ,not any better , now smells more like fuel . sent injectors to DON , did pop test says they are okay. i have been reading and see some saying that when fca goes it full fuels , which could cause smoking and makes alot of injector noise . truck has lot like injector knock noise , can hear it in the exhaust .
Old 06-07-2008, 02:02 AM
DTR's 'Go to Guy'
vzdude's Avatar
You really need to get a scanner hooked up to see what rail pressure is vs. requested rail pressure to determine a failed FCA. Are there any codes? Without some particular diagnostic data, it's gonna be hard to diagnose.
Old 06-16-2008, 11:35 PM
fullthrottle07's Avatar
I just had some problems with my truck is was smoking heavely at ideal and cutting out took it to dealer they could not find what the problem was all i had left on the truck that was not stock was quad boost fooler took it off and now all is well
Old 06-17-2008, 05:12 AM
adventuris's Avatar
well got my injectors back from don , hes says they where fine , changed the fca when i put in the injectors and everything is fine now .
sallyman1
02-03-2009 05:14 PM
Hodges4x4CTD
10-01-2008 02:15 PM
moparman13045
67
10-29-2007 09:29 PM
draskobnsf
17
05-29-2007 08:29 PM
Quick Reply: do i have a bad fca
