Developed a knock.. Need Help..
Old Dec 1, 2006 | 11:37 AM
jbaye73's Avatar
Question Developed a knock.. Need Help..
Need another opinion here guys. I have a 1999 24v and I was pulling my 35' fifth wheel toybox over the holliday weekend and was returning home. I was pulling fine up a slight incline. Then pulled over for a short break. when I fired it back up I noticed a Knock that would speed up when I stepped into the throttle. I continued to a fuel station where I checked all fluid levels. All were fine. I continued home (another 350 or so miles) Not a lick of problems other than the noise. I detached my trailer and changed the oil just because. Knock was still apparent with no noticable loss of power. The guages all read fine, so the only things I can think of would be valve issue or the dreaded #6 cylinder. Any Ideas?
Old Dec 1, 2006 | 07:50 PM
nitrousn's Avatar
You should fill your sig out so we know more about your truck. If its an automatic a cracked flex plate or loose converter bolts are possible.
Do you have a pyrometer? If not i would suspect that you could of melted some metal off the number 6 slug.
Old Dec 1, 2006 | 08:07 PM
jbaye73's Avatar
The truck has a fresh rebuilt Automatic trans with Billit converter. I have a Pyro and the truck never reached dangerous levels.
Old Dec 1, 2006 | 08:31 PM
Charlie8301's Avatar
pyro pre or post turbo? What do you call dangerous levels?
Old Dec 1, 2006 | 09:12 PM
yfz450guy's Avatar
#6 cyl. oiler plugged and siezed. piston slap is what you are hearing.
jm.02
Old Dec 2, 2006 | 12:07 PM
jbaye73's Avatar
Pyro pre turbo and by dangerous levels it never reached 1200
Old Dec 2, 2006 | 12:09 PM
jbaye73's Avatar
I am hopeing it is not the dreaded #6 problem. Is there any way short of pulling the motor to tell if it is a block. I hear that pump could also be an issue.
Old Dec 2, 2006 | 02:57 PM
yfz450guy's Avatar
i just got done going through all this.
let us know if it something though.
Zee
Mar 23, 2010 09:54 PM
jbaye73
Dec 1, 2006 06:15 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
