Cummins Swap into Chevy
Old 06-07-2007, 09:47 PM
CmminsBeast's Avatar
My step son just came back from Indy with me. He's in love with the Cummins now. He has a 83 Chevy half ton he was about to put a 383 in. Now he's kinda hung up on a cummins swap, especially after seeing that 70 chevy/Cummins at Indy. Anyone tried this route before? I'm figuring it to be very expensive.
Old 06-07-2007, 10:30 PM
96_12V's Avatar
Neat idea - try a search, there are many threads on similar topics.
Good luck!
Old 06-08-2007, 12:32 AM
Box5's Avatar
you'll need some different axles for sure, along with front suspension work, then comes the basic swap stuff like probably some frame strenghtening for the mounts etc... Big job but it would be fun...
Old 06-08-2007, 08:04 AM
patdaly's Avatar
Cmmins beast, shouldnt be too bad, I assume you mean 4WD?
PM me, Ive got a 79 GMC 3/4 ton with a 4BT in it that I'm going to yank out and part the rest out, it would be a good starting point for a whole lot less money than converting one yourself.......
P.S. I wouldn't bother with the 6BT, the 4 BT makes enough power to yank anything a 3/4 ton needs to.....
Old 06-09-2007, 08:49 AM
doomgaze's Avatar
I met a guy at Speedway the other day that had a Cummins in his Chevy. Had a 3'' lift and mud tires on it. Said he had a 4cyl Cummins and this is his third truck he's done.
Claimed to get 27mpg out of it!
Old 06-09-2007, 02:31 PM
patdaly's Avatar
doomgaze, I got 26 out of my 79, 4.10 gears and all.......
Old 06-09-2007, 11:20 PM
farmer0_1's Avatar
my 85 suburban with a 6.2 diesel ever gives me an issue or an excuse a 4 bt will be under the hood. take a look at 4btswaps.com i think.
Old 06-14-2007, 11:01 PM
wingnuts0nr's Avatar
well i'm working on a cummins swap into my 1988 gmc 4x4 dually but the half ton non 4x4 would be a chore....
Old 06-15-2007, 12:39 PM
NYCEGUY01's Avatar
If youre handy its not that bad to do . Go over to www.turbodieselregister.com and look in the conversion forum.
You cant look more than a few days back unless you buy a membership. If youre serious it will definatly help out though.
racinrex
06-04-2009 12:54 AM
hartsmike
06-01-2009 10:47 AM
BigDiesel396
11-03-2007 06:46 AM
ro9beam2002
13
08-14-2007 03:59 PM
12vchevydually
01-12-2006 12:32 AM
Quick Reply: Cummins Swap into Chevy
