cruize control
Old 01-16-2009, 06:46 AM
bgflatbed's Avatar
cruize control
1998 1 ton nv4500. The cruize will shut off by itself after bout 10 minutes. The light in the guage cluster is still on and you can resume, but in about 10 or so minutes it will disengage. Short in wire or vacuum?
Old 01-16-2009, 09:51 AM
Fueling around's Avatar
Inspect the servo unit under the driver side battery. They tend to corode. May be a bad connection.
Outside of that you may have a bad connection on the vss.
The most common problem is the brake light switch needs adjustment. If the brake pedal ratles a bit while driving it activates the drop off
Mountaineer
10-04-2011 07:00 PM
ez_lle71
07-25-2008 11:02 PM
frostie
11-15-2006 08:38 AM
bradmar08
06-06-2006 08:49 PM
frostie
08-16-2004 03:34 PM
Quick Reply: cruize control
