Cruise Control
Old 07-30-2011, 07:07 PM
Confedpirate's Avatar
Cruise Control
Does running a Pot going to effect the working of the cruise control?
Old 07-30-2011, 09:10 PM
Onemoparnut's Avatar
If you mean injectors they won't affect the cruise at all.
Old 07-31-2011, 12:02 AM
I mean the Pot, I was having a brain fart thinking it was POD
Old 07-31-2011, 08:50 AM
Jklawinsky's Avatar
It should work still.
Cruise will still work I have the pot and mine works fine.
Old 07-31-2011, 10:56 AM
What it was doing before you would set it and it would cont. to gain speed not set at certain speed, at the time one of the problems was the vac pump was leaking and now that is fixed and read in the shop man. that the linkage is positionable tight with no play.
Old 07-31-2011, 07:03 PM
If it is gaining speed it could be because you have the pot adjusted too high try turning it back in small increments till the problem goes away.
Old 07-31-2011, 07:51 PM
CPesquire@yahoo's Avatar
your cruse problems
My '93 had the same cruse problem with it gaining speed after it was set. I replaced the SET button (found one @ wrecken yard.) with another one .It looked to be in better condition.It fixed the problem....Curtis.
Firstgenfanatic
11-08-2009 04:05 PM
Landini1
03-06-2009 07:01 PM
trophystock
07-06-2006 06:28 PM
sam
03-31-2003 09:04 PM
TexasDiesel
12-27-2002 10:47 AM
Quick Reply: Cruise Control
