Couple questions-turbo/fuel system+Quad
Old 09-02-2007, 12:18 PM
Seeder's Avatar
Have an 06 QC auto and have decided to go with the XZT and probably the boost fooler as well.
My question is what will the stock turbo handle for PSI and do I need to worry about draining the rail while towing 8500-10000 lbs in the hills?
I have gauges so I can monitor the boost and pyro levels but will the fooler and the xzt combo push the turbo too far under heavy loads?
Anything else I should take into consideration or look out for with this set-up? I do not have fuel pressure gauges but I can easily install them if recommended. Thanks for the info. -Jeremy
Old 09-02-2007, 12:45 PM
qzilla's Avatar
You do not need to buy the boost fooler if you buy the XZT. The XZT already has this built in!
Old 09-02-2007, 12:59 PM
Seeder's Avatar
I should have read that other thread first, I now realize this. What about the fuel rail drain?-Jeremy
Old 09-02-2007, 01:39 PM
qzilla's Avatar
The XZT is not even close to draining the fuel rail.
The only thing I have ever seen give us fits are very weak stock lift pumps. I would say that is the exception rather than the rule though.
Old 09-02-2007, 02:00 PM
Seeder's Avatar
Thanks Quad, no one better in the biz than you.-Jeremy
307Kenworth
06-27-2011 08:23 AM
jay_d
15
09-14-2009 08:14 AM
jmd025
10-04-2008 04:42 PM
6 is better tha
09-12-2007 10:16 PM
gman07
04-15-2006 08:32 PM
Quick Reply: Couple questions-turbo/fuel system+Quad
